how to view mbm value in RR?
  • how to view mbm value in RR?
    Hi,
    How to can I view CPU and Case temperature in RR?
    ITALIANI: DISPONIBILI MODULI OEM GPS:
    http://www.mp3car.com/vbulletin/show...214#post639214
    1.First you have to run MBM5.
    2.Check that mbm5 supports your motherboard
    3.Then insert these lines in your skin file
    L08,761,098,060,025,255,255,255,16,"ArialG","MbM2" ,"0.0C"
    L09,761,171,060,025,255,255,255,16,"ArialG","MbM1" ,"0.0C"
    4. Change the coords and the font according to yout nneds.
    These lines will give you CPU and case temeprature.
    The road is long but we are getting there.
      Hi,
      thanks for you reply, I've try but I only have 0.0C, there is some setting in MbM or other plugin to set?
        Check you have updated and selected the correct Mobo in the MBM config.
          make sure MBM is running too -- that's an often mistake. If it is running and you can see your CPU/CASE Temp in MBM, you should be able to view them in RR with the skin changes above mentioned. If not, then your sensor numbers may need to be changed.. there's a MBM sensors tool in my page to show you all the sensors information along with their numbers if you need it.
          Ride Runner RR's Myspace
            I'm sure that MbM is running, I've used this line in menu.skin:
            This is the result of MbM monitor from the guino site:
            Sensor 1: Case / 25
            Sensor 2: CPU Diode / 51
            Sensor 3: CPU Socket / 42
            I've only 0.0C in RR skin!
              sorry this was a bug introduced in the latest version.. download this to fix it:
              http://guino.home.insightbb.com/rr.exe
                Hi Guino,
                Thanks very much, the problem is resolved, thanks!
                  Hi,
                  I have installed MB5 too. I can now display the CPU and motherboard temperature in a skin. But how can I display other values such as fan speed and voltages?
                  Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
                  Software: Roadrunner, Mapmonkey/Freedrive
                  My Car PC project
                  FD & MM voices
                    Just use the sensors program on guinos site and substitute the relevant mbm sensor in the skin for your motherboard
                      Thank you very much!!
                      My Car PC project
                      FD & MM voices
