RR 04-01-05 ... Finishing touch ...
  • RR 04-01-05 ... Finishing touch ...
    New Release.. changes:
    * Fixed another Shutdown Resume Bug
    * Fixed Screen Redraw Issue from 3-30
    * Fixed Radio Playlist Bug when using Card Reset
    * Fixed Skin Browser Showing ".." (sometimes)
    * Added Last Functions of Mappoint (100% now)
    * Added MappPoint Customization File (Optional)
    * Added GotoFirst/Last Skin commands
    * Improved Playlist Display of badly tagged songs
    * Improved "LIST" command (preventions)
    * Improved Album Image Loading Locations
    Look at the Mappoint.ini file to see how to customize Alerts and Zooms.. I have also made the "Pos on road" button switch the Autozoom ON/OFF (Since it did nothing before).
    Album images are now looked for on the folder of the song and ONE folder above if not found in the current folder.
    On the browsers, you can now use Images of same folder or file names to display... examples of matches are:
    D:\Music\Adema\
    D:\Movies\Kill Bill.avi
    D:\Movies\Kill Bill.avi.jpg
    Other than that, just finished the remaining Mappoint functions. I still intend to make some sort of Favorites and Home (maybe integrated) feature..
    Let me know of any issues...
    Thanks for your support..
    Guino.
    Ride Runner RR's Myspace
    sweet nice job! any ideas about the video/video browser screen with the remote? What about calling the on state for a button when you press it down via remote?
    Thanks a lot Guino!
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
      As I said, you probably just have something wrong with your girder file.. you must tell it to send the command to the windows of RR.EXE if you just tell it to send commands to the active window it will not work. I'll do something about the remote buttons, although I should ask, typically you can see the effects of the buttons when you press them on the remote.. why exactly do you feel you need this ?
        Nice one Guino :-) Just in time to install the update before I drive down to the meet later today ... hoping to try both MM and Mappoint
          Sorry man, I don't see any response about this anywhere where was it?
          Thanks I didn't even know about that rr.exe thing I'll have to look at that.
          Having buttons light up on screen when you press them would be cool because you can see what you are doing, like if you are clearing a playlist when you can't actually see the playlist on the audio browsing screen. Not a big thing I was just throwing it out there no worries
            that makes sense..
              D:\Music\Adema\
              OK Guino, you truly are amazing. Not only are you making continuous changes, but you're also making changes that you weren't too keen on making! Thanks, this is just what I was after!
                You're going on Friday?
                thought it was Saturday/Sunday
                  Hi thanks guino for the album art feature i'm seeing allot of art displayed in my skin it's looking great just one thing can you also include .giff as album art as it seems to work if i rename .gif to .jpg so i guess it's not much work to just add .giff.
                  Also cannot wait for slideshow album art if you have time to implement this.
                  www.vortexleather.com
                    I got a problem with MapPoint in my car computer. It run well in my home pc, and I've the same settings in my car. I can run MapPoint stand alone in the car, but when I'm using RR it ends up with a error message. Run-time error
                    '-2147024809(80070057)': The parameter is incorrect. Anyone have a solution?
                    Via Epia M1000
                    512MB RAM
                    120MB IBM Hard drive
                    Netgear MA111
                    Lilliput 8" Touchscreen
                    http://www.clarre.com/carcomputer.htm
                      D:\Music\Adema\
                      Can someone clear this up for me, cause im at work and will try it later tonight........but does this new feature give the ability to display the album art as a icon , rather then seeing the yellow icons in list mode
                      [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
                      [iGmon]
                      Download MP3 MixTapes
                        I updated RR and brushmetal skin today to the latest version and RR has become very slow. I don't know if it's RR or something with the brushmetal skin. Everytime I switch from one submenu to the other it takes a least 10 seconds to open it. Very annoying and I have tried installing everything again but no luck. Till today I was using the 19-02 version wich worked superb. I'm going to try to some more thing (other skin, another winamp, etc)
                        Has someone had this problem before in the past? I remembering reading about this somewhere here but can't find it anymore.
                          The file type/pattern is set in RRConfig.. it's in the Music Section butworks for Music and Videos.. the *.jpg can be changed to *.gif if you want..
                            Try deleting the Mappoint.ptm file, and make sure you've run RRConfig and SAVED. My guess is if you haven't changed your settings for awhile, there may be a setting in the old (wrong) format... The MapPointMap setting used to besaved/loaded as "North America" or "Europe", those are now saved as the number 1 or 2, if you still have the old one you could get what you're saying. Also make sure you have the MAPPOINTERS and the MAPS folder inside RR's folder.
                              no.. at least not yet... I have played around with loading images as icons (for another project) and it is incredibly slow without some type of caching... I'd rather have someone make a Audio/Video Browser screen without the Album art space and with more space for the playlists, then I can work on something that will display the Album "icons" but Bigger and more of them on each screen, and controlled by pages (when it should be ok speed).
