RR 04-02-05 ... Few improvements..
  • RR 04-02-05 ... Few improvements..
    Those are the changes of this version:
    # Fixed HORM support to reload winamp songs
    # Fixed Album Art display on screens with no playlist
    # Improved Flash Commands to prevent unwanted repetitions
    # Updated Mappoint's Brushmetal Skins
    # Improved Scrolling Labels display of empty data
    # Added error preventions to Mappoint
    # Added Support for Custom Indicators
    # Improved Mappoint's Directions
    I've spend most of the day updating the buggy brushmetal skin to use the new features with mappoint.. I still have to add the Favorites list ..
    Thanks for you support...
    Guino.
    Ride Runner RR's Myspace
    I can't keep up!
      nice job Gman.... seems like there's almost only some tweaking left to do now
      Food goes in here..... that's right ... mmmmm
        hi guino,
        update thanks for the numerous ones that you are supplying.
        Optimal job.
        A question: where I can capture the skin for phoco?
        I have tried in all the forum but without result.
        You can help me?
        Guino.
          Originally posted by manung
          hi guino,
          Optimal job.
          You can help me?
          ... with luck UK_MP3 car will have all my skins uploaded later this week... inc a 1.4 BM skin for PC.
          Terran
          My Project Site
            guino great job! cant beleve how fast RR is growing!
            Keep up the good work!
              There's a Phoco Skin available at: http://rmc.pimpedwheels.com/Phoco.zip
              It of course, needs the Phoco support in RR to work (not done yet).
                Hey, great work! The winamp playlist loading for HORM works now. Almost completely finished I think. The thing now is that it always plays the same song on the playlist, even though the playlist changes (Like the 3rd song will always be played on a playlist no matter what was playing before the last shutoff). RR's resume support is a little confused. Stuff like remembering if repeat and shuffle were on isn't saved either (I don't think so at least)... Is there a reload function that is called when RR first starts up? Because that seems like what needs to be called after hibernation to make everything... perfect.
                  When Hibernating, RR saves a resume.ini file (as long as you hibernate using RR's option), that stores your shuffle/repeat, last song used and position playing. When resuming, RR is loading that resume.ini file and if it exists, it will set those options as they were last saved.. of course, this won't happen if you don't use the "Resume" option.. I can only assume the resume.ini file is not being propperly saved when hibernating... this is the last thing done before the hibernate itself.. if your HORM thingy doesnt write any left out cache from memory to disk before shutting off, Id strongly recommend stop using it..
                    HORM doesn't really have anything to do with shutting down any special way. It was created by microsoft so I assume they've thought about any possible problems with it. It's really simple really, you know how when you boot up after hibernating, it loads the hibernation file? Well, with HORM, that hibernation file never gets reset unless you make a new hibernation save or press f8 during startup.
                    I'll do some more testing to figure out whats going on.
                      How do you configure HORM - I'd like to try that out. Thanks.
                        This is the thread I got all of my info from originally.
                        http://www.mp3car.com/vbulletin/showthread.php?t=38484
                        Don't worry about the compact flash stuff.
                          new skin for phoco
                          Hi Guino,
                          I have created a new one skin for phoco (thanks to febsperanza for the file phone.psd)
                          I have a problem as I make to make to work phoco with this skin?
                          In practical when launch phoco from the main menu of RR does not work null and PHOCO it is not loaded.
                          You can help me?
                          Guino.
                            As long as the Phoco.skin file and the phoco image files exist, RR should load it, but Phoco is not yet integrated in RR, so it certainly won't do anything as of right now..
                              Guino, I've got this issue with the playlist. when i click the button to browse my playlists, it shows the list, and then it automatically picks the first one that is highlighted, (alphabetically the first one) and opens it.
                              So i have to reopen the playlists, and then select what it is i want. but even when I go up a dir, it will auto load usually the first dir that is highlighted, or everything in playlist dir since that is highlighted.
