feature request: MM full screen
  • feature request: MM full screen
    Hi Guino,
    I finally made the switch from MC to RR.
    I'm very happy with RR, although I stil have some small issues, which I'm sorting out.
    I have a request, would it be possible to have MM maximise to full screen by tapping the screen twice (and vice versa). I have so much stuff on screen (embedding bar, winamp control, ETA/address info, MM menu bar), that I'm left with a very small map window.
    Maybe a retracting control panel like with Mappoint?
    Thanks, thanks, thanks for your work.
    Michael
    "It does not understand, if it does not ride."
    M10000, 512 Mb, 2,5" 40G, Slim DVD, Opus 90W, Xenarc 7", Leadtek 9532 GPS,
    RoadRunner, MapMonkey, Pioneer HU, Pioneer 4 ch 400W, Kappa 6.5, Basslink X 200W
    The Infobar of MM you can disable in MM's config. You can get rid of all the stuff on the bottom of the skin by renaming your DESTINATOR_GPS.SKIN file to something else and renaming your OLD DESTINATOR_GPS.SKIN to just DESTINATOR_GPS.SKIN. This action will basically only leave a bar on the top with the date/time, song title and controls to close/exit of screen. This is EXACTLY the same space MC uses.. There's no easy way for me to capture the actions performed in MM such as clicks etc. This would require a lot of code for so little reward..
    Ride Runner RR's Myspace
      Ok, thanks will try that.
      Michael
