2 Q's, SuperSpinFlash and WinAmp Visuals
  • 2 Q's, SuperSpinFlash and WinAmp Visuals
    I have noticed that lost of people have asked about the "SuperSpiningFlash" logo in the skins. I have downloaded the DLL from the site, but it doesn't say where to put it! I have tried in the RR directory and System folder but the logo still spins a super sonic speeds... What am I doing wrong?
    Another problem I have is that when I hit the Visualization for the music WinAmp loads up the vis, but it doesn't get put into the display and ends up behind RR. I noticed that WA5 (which I am using) doesn't create a seperate window, is that why RR can't find it? Or should I use WinAmp2?
    Cheers from a confused bunny! LOL
    Place it in c:\windows\system32 then go to start run and type regsvr32 c:\windows\system32\flash.ocx
    Not sure about the visualisations - I'm sure someone else knows the answer to this.
      Have u checked ur settings about the vis title??
      even in winamp5 u can show the vis in a sperate window... its something like dtacht visuals or something like that... worked for me with the right window title ....
      Fiat Punto 176 Cabrio CarPC Projekt
      Status: finished (you never really finish... lots of new ideas)
        use winamp 2, i had 5 and lots of issues. 2 is faster anyway
        Peep MY TYTE WHIP yo! It's got too many ill mods to list!
          If you use winamp 5, disable the modern skins -- use a classic skin.
          Your visualization is detached because you probably need to make sure your default (selected) visual plugin in winamp is setup in RRConfig.
          Your flash spins too fast because you probably haven't updated your flash version. There's a whole FAQ just on this.
          Ride Runner RR's Myspace
            That got it, thanks!
            Sorry I had a quick look in the FAQ section but didn't notice it .
            Cheers, great program, far better then the other one I was using before
              Yea Guino,
              I have just got around to setting up the visualization in the car and i comes up ok but as far as clicking/touching the right side of the screen it doesn't work...
              I am using milkdrop currently with it set as default in wimamp and RR config. tried several options and still have probs getting out of it... The only way I can get out of it is to tap twice and after it goes to the smaller window, hit the vis button again...
              Any thing else that you could suggest....Thanks,
              Next in line: RRMedia v2.0
              DFX 5.1.1 Skin
              Appstore Link
              My RideRunner Plugins
              RRMedia
              RRExtended
              DFXVoice
                Just make sure that your plugin (MilkDrop) is changing the screen's resolution when in Full Screen -- this is what RR detects to allow the right-edge clicks to disable VIS. If MilkDrop is set to use the same screen resolution you use in RR, this will not work (only the double click will). I suggest lower resolutions for improved speed...
                  Ok, I tried this and any thing else that I could think of and still no luck....
                  I did notice two things though:
                  1. Tried to tap on the screen anywhere, and when i taped twice over where the playlist was it changed to whatever that song was...like the vis was a portal and could just reach right though it...normal??
                  2. After I get back to the sm vis window and hit the vis button and go into the audio browser I can see the area that I should have been able to use to close the vis...like 2" of the right side...its white. Then I have to close RR to make everything normal again....
                  DFX 5.1.1 Skin
                  Appstore Link
                  RRMedia
                  RRExtended
                  DFXVoice
                    Same problems here...
                    When i run winamp the visuals are fast enough, so i dont think i need to lower the resolution.
                    But great front end, RR its my choice!!
                    Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
                    http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
                      Guino above said that you HAVE to make sure that the vis changes the res cause thats what RR uses to detect the vis to allow being able to touch the right side of the screen...
                      But, I would have too agree too...the higher res didn't have any probs either, just that I can't get out of it the way you should be able too...
                      DFX 5.1.1 Skin
                      Appstore Link
                      RRMedia
                      RRExtended
                      DFXVoice
                        If you use AVS, with the full screen overlay and pixel doubling option, it will not change screen res, will be full screen and a click anywhere on the screen will come out of FS.
                        MilkDrop Embeds better but it doesn't manage FS that well, so anything trying to update the scree gets to do it (RR) -- unless of course you make it change resolution then RR nows better not to try and update the screen..
                          anyone ever get overlay mode working with m10k? mine is all green, so i just sorta gave up on it............
                            Tha'ts probably because you got a cheap Video Card with no overlay support in there.. anyway, I ran RR in a Win98 on a Virtual machine and it worked fine.. the virtual machine of course has no support for overlay so I turned it off and set it to 640x480x32 and it worked fine simply using the pixel doubleing.. Also re-tested the righ corner disable vis feature thing.. it works fine as long as the resoution is changed...
