Display labels from FreeDrive
  • Display labels from FreeDrive
    Lo, first of all sorry for being thick, but trying to suss this out. OK.. say I want to display my speed on any page in RR.. I assume I must first set a label up in the skin as follows - Lxx,xxx,...,"!FDSPEED","Loading..."
    Now, do I just use the same type of commands to send to RR ? Like COMSend "RoadRunner", !FDSPEED, "30"
    that type of thing ?
    Follow me on Twitter
    http://www.FreeICE.co.uk
    Put the !FDSPEED in Quotes like "!FDSPEED" in the COMSend string
      ah cool thanks will give it a go
      CdR
        ok just add bit of code into freedrive so it 'should' now be able to send info out.
        I have hardcoded in this line, just to see if its working..
        COMSend "RoadRunner", "FDSPEED;30"
        now.. in my flash I have added a dynamic variable which is looking for a variable called FDSPEED, and I have also added the following line to the menu.skin (main menu) which should be all I need to do, but its aint working
        L11,000,000,000,000,000,000,000,14,"Arial Narrow:B","!FDSPEED","test"
        now I cant set !FDSPEED in flash as a variable, which maybe where its getting stuck.. any ideas ?
          ok got it working in a normal skin, but the ! but is giving problems when trying to call the variable in flash..
          CdR
            Then we'll have to define something else for it to work in flash -- I wasn't sure this would work, but I have to specify some type of identifier in RR for custom labels or it will blank out any unknown tags.. You can either cut the flash and show the native "custom" label, or I can add something like "CUSTOMXXXXX" tags support where "CUSTOM" and "!" do the same thing..
            Ride Runner RR's Myspace
              yeah that would be good.. Got it working now with 10 out of the 12 different labels FD can send.. only 2 left :-)
              CdR
