RR and Girder - How to add command
  • RR and Girder - How to add command
    Hi,
    now I've config Girder and RR, they works great but I haven't find the TV command and a PowerOff command-
    There is a way to add?
    Antonio-
    ITALIANI: DISPONIBILI MODULI OEM GPS:
    http://www.mp3car.com/vbulletin/show...214#post639214
    You can add any Skin Commands defined in Skin Commands.txt -- the file provided is only an example. Basically, simply duplicate any of the existing commands then rename it and under the Command tab (right side) edit the command on the eventstring you made to show the skin command you want to execute..
    For instance, if you duplicate the "UP" command, that's what it'll be on the command tab.. change it to "TV" or "POWEROFF" (or whatever the right command is), save it, and it should work.
    Ride Runner RR's Myspace
