all music from all drives to one playlist or library
  • all music from all drives to one playlist or library
    I have been trying to get all of my music from C drive and also external usb drive to list as a single library or even as a comprehensive playlist. I have created a file with an alternate pathway to the external drive but I must click on the folder to get the list of albums/songs. What I would like to do is have the entire music collection be able to be randomized. is there a way to set the music path to the winamp library? or maybe set up a playlist in winamp with all songs and set the music pathway to the playlist file?
    thanks
    glenn
    you can do both of the above.. just make a browse.rrl file with the locations you'd like to have on your list.
    Open the Audio Browser and for each of the entries on your browse.rrl file hit the +1 button. It will add each of those folders to the playlist. when you're done just pres exit and it should have all your folders on the playlist.
    You can also make a playlist file in winamp with all the songs you want, place it anywhere you can browse with RR (your music path for instance) and go into the audio browser and hit "play" (select) with the playlist hightlighted -- RR will load the playlist file. It must be a .M3U file.
    Ride Runner RR's Myspace
