Error with Gamma mode
  • Error with Gamma mode
    Hi,
    I have an error while I'm trying to change the gamma Night/Day with a button in some skins (brushed, alpine..).
    RR returns "'0.92' is not a valid floating point value".
    It does the same in my own skin, the button has the command "GAMMA".
    What I'm doing wrong ?
    Originally posted by delkro
    Hi,
    You are European?
    Try open general.ini file of the skin that give you problems and change 0.92 in 0,92 and to the same with the other values...
    See my car and donate for spinning logos at www.ildena.it/carpc
      Its your regional settings. You probably have .92 think it should be ,92
      Change all the "." to ",".
      PowerVoice v1 | NaviVoice Source
      GammaControl v2.4
      SKINbedder v3
      1995 Lexus SC300
        Ok ! Thanks !
        The problem was in the \RoadRunner\Gamma\Gammacontrol.ini
        0.92, instead of 0,92 (I'm in France)
          Ok ! Thanks !
          Yeh... I hope that probelm will be gone when I switch to XML.
          GammaControl v2.4
          SKINbedder v3
          1995 Lexus SC300
