Update my first hardware (Serial Voltmeter).Add two new functions
  • Update my first hardware (Serial Voltmeter).Add two new functions
    Four functions with a one hardware:
    Serial Voltmeter (see my old thread )http://www.mp3car.com/vbulletin/showthread.php?t=44181
    Timer for power GPS when the PC and out
    Automatic switch VGA-AV and AV-VGA with input from the lamp reverse of the car(only for Lilliput) connect in parallel to the switch original for rear cam use
    Automatic fixed lighting of the blue leds of the keys when the lights of the car(only for Lilliput) connect to the pin 8 and 12 of the Lilliput
    In the future I put in download the material for to build "home made" this hardware
    In enclosure the photo of the new hardware
    Mauri
    01/05/05
    UPDATE PHOTO NEW VERSION OF THE HARDWARE
    Edit: ALL the Input -Output in the new board is optoisolated.
    For all guys:
    If you have the Lilliput monitor (7" TS) I ask you to make a test:
    Turn on the PC and also the Lilliput, tries to push the button AV to manually go to AV1 (the PC has to be in initial phase of boot) and tell me if Suffered the Lilli, only in this condition (first 5/8 second max of operation) succeeds in commuting from VGA in AV1 or no.
    Do you him to know in this thread.
    I assume the AV/VGA Lilliput switching can get out of sync if you swap the modes externally via the button and/or remote, right?
    2004 4runner
      The Pic simulates the input on the original button of switch of the lilliput VGA-AV.
      Mauri
        I am sorry but I didn't get it. Will this device switch the VGA to AV1 and 2 on a lilliput automatically hen the reverse light is on and then back to VGA when it is off?
        Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
          YES!
          default VGA
          turn the revers light
          switch VGA-AV1
          off revers ligth
          switch AV2-VGA
          Mauri
            Cool...I am off reading your original thread. Hope you have info on how to build or buy over there....
              I have built" home made" ALL....
              The old version is in download in my web space (see the link) by now for a while, full version, and compatible to 100% with RR (thanks Guino)
              Also the new version and perfectly already it works (tested).
              I use this rear Cam,waterprof, in enclosure the photo
              Mauri
                I read the other threads and downloaded the project. Unfortunately it is way over my head. Will you build and and sell one to me? I only need it to switch the lilliput. Thanks.
                  are you selling these built. I may be interested
                    NO,I don't sell this.
                    My idea and for everybody, free, to build him "Home made"
                    Mauri
                      Mauri
                      Unfortunately I don't have a way to program a PIC so I guess I can't have this. Thanks anyway...
                        In the web is possible download many simple hardware to burning the PIC device.....And sw free (type IC-PROG)
                        Mauri
                          I have a similar camera, the same actually, but with IR... I really like it in case you guys are looking for one! I wrote a review on here just search for "REVIEW" and my username...
                          </hijack>
                          Roy
                          2005 Range Rover 4.4
                            Mauri is possible to implement this on xenarcs someday??? or is to hard to go from lilli to xenarc confi...??
                            RexBruMet Skin for FrodoPlayer
                            Nissan Aux-in MOD
                            Originally posted by bgoodman
                            We're an international forum, post in whatever langauge you like.
                              I have made the tests with the Lilli....
                              But the Xenarc if I am not wrong it already has the automatic functions to switch VGA - AV..
                              However if the Xenarc has the button for the manual switch VGA-AV in theory it works equally my hardware.
                              EDIT:If you connect my hardware to the Lilli, ALL the original /manual functions(timer -led and manual switch VGA-AV) work correctly!
                              Mauri
