Problem: Master Volume at 100% at startup
  • Problem: Master Volume at 100% at startup
    I have a problem.. When i turn on my Carputer the master volume of RR is always at 100%. In both cases ( Hibernate by windows or hibernate by RR Exit-Menu at 10 - 20 ... % volume ) when restore the volume is 100 %. Note that Winamp and other volume settings are correct.
    What can i do ?
    very thanks at all !
    Since it is after hibernation you must be using Audigy 2 NX (USB).. right?
    Go at and download the latest drivers!
      Thank you for your reply
      i use Audio Card integrated in my PC (ex notebook ). Until i have intalled RR, with
      only Winamp i haven't the problem... Now, If I use only winamp no problem with audio volume....
        I'd make sure you have the latest drivers for your card.. if that doesn't fix it, do a search on Mixer Presets and you can "fix" this by loading a defined mixer preset when starting or exiting RR. You should also try to map the master volume to a audio line in RRConfig.
        Ride Runner RR's Myspace
