Backup cam + Road runner help
  • Backup cam + Road runner help
    Hey all, I have a 3com home connect USB webcam I plan to use as a backup cam. I am using Road Runner front end. For some reason, I can't get the Winamp TV plugin to reconize my camera.
    In the Video tab, it sees the driver for it. Then, when I go to "Add Manually" my camera, in the "Other inputs" drop down menu, all that shows is "Default". For some reason, it's not seeing my camera. All drivers are installed correctly along with Road Runner and Winamp and plugins.
    Any suggestions? Also, I don't know what "WDM" means in the FAQ on this subject. What's it mean to have a "WDM Webcam"?
    Alright, for some reason. Just playing around, I opened Road Runner and hit TV and it works. Odd. Thanks anyways, guys.
      WDM means "Windows Driver Model", it's the native type of drivers used by Windows 2k/XP.
        You could better use frodocam!
          for some reason though FrodoCam slows the frame rate from 25+ to less than 10fps @ 640x480.
          Other than that and the fact it doesn't record or capture its perfect
          My Nissan 200SX @ Silverstone
          NOW SADLY WRITTEN OFF!
          My Car's spec list + pics
          Stealth CarPC fab'ing...
            For reverse camera I need inverted picture. How can I mirror picture from camera in RR?
              not to hijack the thread, but topic is similar
              does anyone know of a camera app that has no UI? just a single window for the camera video and no buttons?
              options configured through a rightclick
              beer replenishment fund
              mp3car live search
                P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
                  Alot of cam tools have a feature to reverse the image.
                    I think you might want this
                    http://www.snapfiles.com/download/dlvideothumb2.html
                      I know, but what (and how) use in RR?
                        I would like to know this as well...
                          Logitech Drivers allow you to invert the camera image ... other than that you'd need a little application... AMCAP is the simplest thing I know for camera.. and works very well, but it is menu based (not that you need to use the menu).. don't think it has "reverse image though"..
                          Ride Runner RR's Myspace
                            I've installed original Logitech drivers, inverted picture and now it works perfectly with RR! Thanks
                              Can somone help me invert my intel? (Damn that sounds bad)
                              I hooked up an Intel® Deluxe PC Camera Model CS330 ( http://support.intel.com/support/cre.../CS-015592.htm )
                              And i got it to work with RR using the same TV function as JeremyM (thanx btw).
                              However, Intel isn't providing the drivers for this (plug n play only) So is there a 3rd party i can use to invert the image?
                              Jackdaws Love My Big Sphinx Of Quartz
