Artist/Song
  • Artist/Song
    I don't know if this is possible, but I assume it isn't since I haven't seen it in any of the skins.....
    Is it possible to display Artist/Song in the playlist or current song... I assume this is a responsibility of ID3... but I'm an MP3 dickhead, and I haven't read RRs docs, so forgive me in advance for not reading or stating something obvious.
    Should you decide to chew on my *** for the aforementioned, be advised I have just returned from a 4000km trip and my *** is rock hard and a bit ripe
    Isn't freedom of speech great!
    I'll answer just because I like Canada! (j/k)
    in RRConfig, you can set the music format to: %artist% - %title% .. but you'll need to enable ID3 support for it to work (right above it) -- I suggest Mix v1v2 (faster) or mix v2v1 (better format). Keep in mind that if your ID3 tags are F$%# up it will display them wrong because I can't guess the right info..
    Ride Runner RR's Myspace
      I just knew that this was a situation. Ok... I'm just lazy .
      Thanks for answering Guino... for my penance, I'll walk 3 times around the lake and chase an Elk... eh (when in Canada...)
      EDIT: Thanks BTW... that worked nicely! Just how I wanted it!
