Default Applications do not work.
  • Default Applications do not work.
    For me the default embedded applications do not work.
    For example Notepad and Calc. I have both installed (default in Windows2000) But both won't start when I select them and hit launch in RR.
    I didn't change anything in the Launch folder, I assume that the default settings are correct to get the applications to work.
    These are the ini files I have for notepad and calc (both default)
    Notepad:
    [GENERAL]
    PATH = C:\windows\system32\notepad.exe
    TryEmbeddedTimeOut = 5
    WindowSearchString=notepad
    Calc:
    [GENERAL]
    PATH = C:\WINDOWS\system32\calc.exe
    WindowSearchString=calc
    I've checked the paths and both are correct. But it won't work, can anyone tell/explain me why it isn't working or what I'm doing wrong?
    If as I presume you are using windows 2000 then the path should probably be WINNT not WINDOWS.
      yeah, having the right path is a good start. Windows 2000 is on WINNT and NOT on WINDOWS as sjwaldock stated.
      Ride Runner RR's Myspace
        omg how could I miss that, Im a network admin for a living, this is something I should have seen myself.
        Thanks sjwaldock & Guino
