Go Home funcion on Browse button.
  • Go Home funcion on Browse button.
    I'd like to be able to listen to music from CD and mp3's from my hdd. I've made a BROWSE.RRL with the line: " E:\;>CD-ROM Drive< ". I've put this in my mp3 folder and it works.
    However once I play music from CD, I cannot go back to the playlist by holding the Browse button (go home function)
    Does the go home function only work with a touchscreen (I recall it working when I used that) or does it have to work on a normal mouseclick too? If it is supposed to work with mouse too, what could be wrong?
    well im pretty sure that's nothing to do with a TS or normal mouse.
    windows reconise a TS like an normal mouse, including movement and clicks.
      just press and HOLD the button "Browse" the one that goes into the folder. Make sure not to move the mouse too much while holding it down... alternatively, you can edit/make a button with the code: "!BROWSE".
      Ride Runner RR's Myspace
        Again the answer to my problem is simple. Turns out I was moving the mouse too much. Thanks again Guino
        So there isn't a browse button in the BrushMetal skin? Will it be included in a future release?
          as far as I know there's NOT a single screen WITHOUT a browse button ..
