fsCommand in RR
  • fsCommand in RR
    Hi all,
    I have a little problem with the fsCommand from a flash movie.
    I created an access screen in flash where you input your access code to start the Menu.skin in RR. The first part works when the right code pressed, it will start the menu skin. The second part with the wrong code does not work.
    Here is my code in flash.
    on (press) {
    if (display_total == 5689) {
    fscommand("load;MENU2.skin","");
    } else if (display_total<>5689) {
    display_total="";
    display_total_x="";
    fscommand("RUN;C:\playfile.exe|c:\WrongPin.wav","" );
    The second fscommand does not work. I tryed this within flash but you can not use the playSound command in an if Statement.
    Any Idea's?
    I would prob split the flash up to point to certain frames in the movie.. as you said the load;menu works fine, but to play the sound and reset the movie I would prob use a goto and play movie from frame 100, then on frame 101 play the sound, and on frame 102 goto and play frame 1 (restart the movie) then when your intro is done again, just say stop on frame 20 or something.. hope you get what i'm trying to type
    cheers
    CdR
    Follow me on Twitter
    http://www.FreeICE.co.uk
      Thanks, that gave me some idea's. Have it working now.
