DVD Player not working
  • DVD Player not working
    before I get flamed..I did
    I just download the lates and greatest version of RR.
    Here's the part I don't understand....DVD plays fine under MP classic.
    Once I open RR...It does nothing Could someone explain what I'm doing wrong...I download PowerDVD and it played choppy. Here's what I have Via800, 512ram, 40g HD....Thanks in advance
    Crazy Miami Drivers
    R.I.P. My first ever NEW Car
    Old installation
    New Install!!!
    |-------------------100%|Cables ran
    |----------------85%----|Software RR
    |--------------80%------|Complete
    [/SIZE]
    can i suggest you try the freeDVD codec i found on the web PM your email and I'll send it across.
      PM sent....Thanks man
      Crazy Miami Drivers
      Old installation
      New Install!!!
      [/SIZE]
        Look at your menu.skin file.. the button definition for the DVD should be "DVD" ... it might be commented out right now because I was testing the PowerDVD/WinDVD interface.
        Ride Runner RR's Myspace
          Thanks Guino, I looked under C:\Program Files\RoadRunner\Skins\BMV2--->here's what I got:
          External_DVD.skin
          Powerdvd_player.skin
          Which one do I change? Thanks....
          Crazy Miami Drivers
          Old installation
          New Install!!!
          [/SIZE]
            In the menu.skin m8, not the dvd skins
              Here's what I got?
              Code:
              B03,011,181,321,116,"DVD","DVD Player"
              Crazy Miami Drivers
              Old installation
              New Install!!!
              [/SIZE]
                that's ok, now make sure that line starts with that B (nothing in front of it) and that the lines that have Power/WinDVD are commented out ( / in front ). The skin you should see on the DVD player is the same one as in the video player. As long as your MPC path setting is correct, it should work.
                  Code:
                  MEDIACAR Skin
                  MEDIACAR F-CNS(800X600Stretched)Menuskinskin skin
                  /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
                  B01,011,068,369,116,"AUDIO","Audio player"
                  B02,418,068,369,116,"VIDEO","Video player"
                  B04,466,181,321,116,"RADIO","Radio"
                  B05,011,300,369,116,"LAUNCH","Launcher"
                  B06,418,298,369,116,"GPS","GPS"
                  B14,010,415,135,110,"TV","Tv"
                  B13,161,425,65,90,"MUTE","Mute"
                  B12,237,427,51,64,"VOL-","Volume-"
                  /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
                  S01,273,472,255,030,273,472,255,030,H,01,"SLIDER3\POINTER3.gif",013,"MASTER","Master"
                  B11,519,427,45,59,"VOL+","Volume+"
                  B07,570,425,69,90,"MIXER","Mixer settings"
                  B15,652,415,135,110,"RADIO","RADIO"
                  B10,28,530,226,70,"APPEARANCE","Appearance"
                  B08,288,530,226,70,"EXIT","Exit"
                  B09,544,530,226,70,"GAMMA","Gamma mode"
                  /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
                  L00,430,440, 50, 30,255,255,255,13,"Arial Narrow:B","VOLUME","Volume"
                  L01,025,010,200,030,255,255,255,18,"Arial Narrow:B","TIME","Time"
                  L02,025,040,200,030,255,255,255,18,"Arial Narrow:B","DATE",""
                  END
                  I don't see a Power WinDVD???? those code are under menu.skin
                  Crazy Miami Drivers
                  Old installation
                  New Install!!!
                  [/SIZE]
                    Ok, your skin is fine, now what is the MPC path setting you have in RRConfig ?
                      Set to C:\Program Files\Road Runner\mplayerc.exe
                      and under Video settings "use External DVD Player" is unchecked.
                      MP Classic is in that folder....
                      Crazy Miami Drivers
                      Old installation
                      New Install!!!
                      [/SIZE]
                        FYI: Once I hit DVD on RR, my dvd doesn't even spin
                        Crazy Miami Drivers
                        Old installation
                        New Install!!!
                        [/SIZE]
                          Ok, you press the DVD button, does it even launch MPC and show the controls ?
                            it show control under RR and then hangs for a few seconds...DVD drive doesn't even spin....If I open MPC by itself...it works no problem.
                            I know its something I'm doing wrong since I see no one eles with this issue..
                            Crazy Miami Drivers
                            Old installation
                            New Install!!!
                            [/SIZE]
                              If you don't see the 321 "picture" in the middle of the screen, then your MPC path is wrong, if you see it but nothing happens, then there may be something wrong.
