Problem whit cdrip whit rr
  • Problem whit cdrip whit rr
    Hi Guino
    I have two problems with cdrip:
    1) I do not succeed to close cdrip without to make to hide rr. In fact when I press the button exit in cdrip it closes itself but rr it hides and is visible only with taskmanager.
    2) I do not succeed to make to work cdrip with the cddb local. I have unloaded from Internet cddb (362 Mb) and have inserted the path in cdex ( option, setting , cddb locale), but it does not work. In fact if internet is not active , cdrip does not recover the information.
    note :
    with cdex the cddb local it works well
    how I can say to cdrip recovering the information from the cddb local?
    You can help me?
    I don't think the cddb local is working yet ... only internet based cddb.
      therefore the access to the cddb local is a function not implemented that guino it could implement?
      thanks
        1-you're probably not using then PLUGIN command to run it.
        2-I haven't implemented that yet, just need to find time to do it.
        Ride Runner RR's Myspace
          1- ok
          2- ok as soon as you can.
          Guino I have noticed that when I press the button exit, rr it does not return in main menu but remains cdrip and on the bar of the applications flashes RR. If I press on rr on the bar of the applications it it appears and if from the main menu I press button the CDRIP appears the image of RR Loading, but it does not happen null. I imagine that it is a problem which had to the fact that cdrip is still experiences them? As usual I enclose one photo in order to understand to you to us better. Thanks
          NOTE :
          I use "PLUGIN;cdrip;C:\Programmi\RoadRunner\CDRip\CDRip. exe" in the main menu and "SENDMSG;RoadRunner;exit" for exit button in cdrip
            The Plugin name to use in RR is RRCDRip and not CDRip.. once you fix that, RR will acknowledge and control the Plugin (because then it will be able to talk to it). So use:
            "PLUGIN;RRCDRIP;C:\Programmi\RoadRunner\CDRip\CDRi p.exe"
            Note that the CDRip will stay running if you close RR. You'd have to change the exit button code (CDrip.skin) to "QUIT" to make it quit when exiting it's skin (this prevents you from using other screens of RR while ripping a CD on the background).
              Ok, I've worked a bit on the CDRip today.. added a minimize and a exitplugin "smart" command to the plugin. For minimize you'll have to edit the skin images to make a button for it (to run in other front-ends).
              You should download the CDRip binary package from my site along with the Skin for it (unzip skin package in the BrushMetal folder if using in RR -- or at least the cdrip.skin file).
              You should add those TWO lines to ExecTBL.INI if you don't want the CDRip hidden on the background when exiting RR (and the CDRip is busy).
              "QUIT","SendMsg;RRCDRip;showplugin||BYE"
              "BYE","QUIT"
              I'll post updated FULL skins when possible...
                "BYE","QUIT"
                excuse guino
                I have made as you say, and the result is:
                launch rr,
                I press the button rip in the main menu, appears cdrip.
                I press the button esc in cd rip and the result is that rr it is closed, but cdrip is run.
                Where I am mistaking?
                note:
                In the main menu i use : "PLUGIN;RRCDRIP;C:\Programmi\Road Runner\CDRip\CDRip.exe"
                In the cdrip i use "SENDMSG;RoadRunner;quit"
                In the exectbl i added this line :
                "BYE","QUIT"
                  You did NOT download the CDRip SKIN as I told you to do. Did you even download the Updated CDRip Plugin ? If so, just change the EXIT button code on CDRIp.skin to: "EXITPLUGIN"
                  This will TERMINATE RR: "SENDMSG;RoadRunner;quit" (you don't want that).
                  Originally posted by manung
                  excuse guino
                  launch rr,
                  note:
                  "BYE","QUIT"
                    ok guino
                    I have made confusion.
                    Hour I sure have new cdrip and the new one skin of cdrip.
                    When start cdrip from the main menu of rr, appears the image of loadin, but it does not succeed null, it seems that rr it jams. I have tried launch cdrip without rr (setting up the path for the skin) and works. In main menu I am using this command: "PLUGIN;RRCDRIP;C:\Programmi\Road Runner\CDRip\CDRip.exe" What has happened now?
                    thanks for your patience
                      make sure the CDRip is not loaded/hidden in the background, I suggest restarting the machine, the above works really well. This is all you need:
                      Main menu: "PLUGIN;RRCDRIP;C:\Programmi\Road Runner\CDRip\CDRip.exe"
                      In the cdrip.skin exit button: "EXITPLUGIN"
                      In the exectbl.ini:
                      "BYE","QUIT"
                        I download the ney version and the skin again..... also add a exit button to the jpg.
                        But I'm lost in what the label for the button is ....
                        I checked the .skin file but I don't see the label for minimize
                        Thanks...
                        RexBruMet Skin for FrodoPlayer
                        Nissan Aux-in MOD
                        Originally posted by bgoodman
                        We're an international forum, post in whatever langauge you like.
                          Thanks...
                          Just add this to cdrip.skin:
                          B99, 000, 000, 100, 060, "MINIMIZE", ""
                          It will create an "invisible" button at the top-left of the screen. The numbers are X,Y,Width,Height.
                            got it!!!!
                            I wasn't sure on the content......
                            But this answer my question pretty good!!
                            Thanks guino
                            edit:
                            Work like a charm.....
                            1000 thanks for support a non RR user
                            Nissan Aux-in MOD
                              In the exectbl.ini:
                              "BYE","QUIT"
                              Ok I have modified exectbl.ini, the button exit in cdrip.skin and the button rip in main menu. When I press the push-button exit in cdrip, the plugin cdrip it is closed and rr it continues to work but hidden. I have tried to insert the following command in cdrip.skin: "SENDMSG;RoadRunner;close" and when I press the button exit in cdrip it to hidden and returns rr, but cdrip continues to work but hidden. All this goes well, but as I can close cdrip without to use taskmanager.
                              Note :
                              also when use the commando minimize, hides all and not only cdrip
                              thanks
