Problem exiting from gps skin
  • Problem exiting from gps skin
    I am currntly using Dena Old Style skin and am experiencing problems when exiting direct from the external gps screen (usin freedrive 7.0)
    if I exit direct from this screen freedrive remains open but if I go via main menu screen freedrive closes fine anyone experienc similar?
    PC Chips 1500,512mb ddr,no case yet, LinITX 7" touchscreen,300w inverter,RoadRunner FreeDrive,BU303 gps mouse.
    Freedrive will stay open in BOTH ocasions.. it's just going to be hidden if you exit through the main menu. There should be an actual "CLOSE" button to shutdown freedrive. Otherwise you'll have to add a code to run when closing RR to close Freedrive automatically when open.
    Ride Runner RR's Myspace
      Guino might you possibly add an option to close all external apps when road runner is closing? I run quite a few extapps, and sometimes they stay open.
      Any idea?
      Roy
      2005 Range Rover 4.4
        Just make a long command on exectbl.ini to close the applications when the quit command is issued.
        "QUIT","CLOSEWINDOW;<APP1>||CLOSEWINDOW;<APP2>||CL OSEWINDOW;<APP3>||BYE"
        "BYE","QUIT"
        It won't hurt anything if the app is not running. The parameter is the same as to embbed the applications.
