RR 06-21-05 ... Improvements and Fixes..
  • RR 06-21-05 ... Improvements and Fixes..
    On this release of RR:
    -Added Local DB Support to CDRip (Windows FreeDB format)
    -Added skin commands: "PREV2" and "SEEK"
    -Added "ONSUSPEND" and "ONRESUME" events
    -Added commands to open/close Winamp
    -Added commands to Detatch/Embed Map Monkey (split GPS screen support)
    -Improved Phoco integration (various fixes)
    -Improved RR's Menus to allow calling of any menu from any menu
    -Fixed issue with using PAUSE/RESUME commands on XM with Line in plugin
    -Fixed Custom Label variables in Flash
    -Fixed bug with Winamp Library if winamp not in default path
    -Fixed bug with SDK taking focus away from FreeDrive
    -Fixed bug with Web Browser not embedding propperly on first run
    -Improved Internal Interfacing of CDRip plugin
    -Updated Brush skin files for CDRip
    -Added Phidgets 8/8/8 Temperature Reading support (Tested and PATCHED)
    Notes:
    -Local CDDB MUST be the uncompressed windows format. If you wish to compress it you can create a compressed NTFS virtual disk using FileDisk or use DriveSpace (Win9x/Me) -- You'll reduce the size about 600Mb.. No, I can't make it work out of the RAR package, also making it work with a Zip package would require you to re-compress it and also would make it quite a bit slower.
    -"ONSUSPEND", "ONRESUME" commands are optional and can be set on ExecTBL.ini
    -I made a "virtual" command on ExecTBL.INI simplify the setup of the CDRIP plugin. Just set the path for it in ExecTBL.INI and you're done.
    -Haven't tested the phidgets interface, but I just "copied" code I've seen posted. You can use "c2f", "f2c" and "" as format to display the values in C, F and raw value respectively.
    Look at skin commands.txt for other commands/changes.
    Thanks for your support,
    Guino.
    Ride Runner RR's Myspace
    look good, good job
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
      Thanks Guino
      Fabio
      _______________________
      Travla C134
      Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
      RoadRunner - PC Navigator 7.1 - FreeFone
        Will check it out thanks
          Thanks Guino!
          The MM Detatch/Embed makes MM work perfectly.
            How do you install the CDDB?? im so stupiiid???
              HEHE, I beleive as of yesterday morning you were experimenting with CDDB Local. Then, all of sudden, you're like bam new RR release with tens of thousands of updates - damn you work quickly. Exciting changes! Especially 1st try web browser embedding.
              Its not the cards you're dealt, its how you play the hand!
              Originally posted by ryuandwings
              Where can I get a roll of tin foil?
              I been looking for that all over the net, but I can't find it.
              Please help.
                -Download: ftp://ftp.wu-wien.ac.at/pub/info/fre...n-20050104.rar
                -Unpack it anywhere in your HD
                -Open CDRip.ini
                -Set: localdbpath=<PATH WHERE YOU UNPACKED THE CDDB>
                -Save
                That's it...
                  I have updated the Install to include this version and all updates to the Skin.
                  Bryan
                  2000 Yukon Denali
                  Shuttle SN65G2
                  Cel-D 2.4 GHZ 533mhz FSB
                  1GB PC800 Mem
                  Radeon9200 PRO
                  Seagate 120GB
                  ATI Remote
                  RF Mini Kb w/Trk Ball
                  7" Lilliput Touch Screen Monitor
                  USB 2.0 Hub
                  Rikaline GPS-6010
                  PN11 802.11b Wireless
                  XP Pro
                  750W Inverter
                    Web Browser still not embedding propperly on first run.
                    Anyone else having the same problem of the Web Browser still not embedding propperly on first run.?
                    updated Road Runner using Road Runner Updater and also tried downloaded the updated skins but does not help.
                    It does embed corectly but then it "pops out in front" the fist time. after the first time it is perfect.
                    No big deal just thought if anyone else has this problem still.
                    Thanks Guino for all your hard work with this Great Frontend.......
                    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
                    1.)Orion 2500d Amp
                    1.)Orion 15" h2 Sub
                    1.)Orion 8004 Amp
                    2.) Sets Orion Components - P-SERIES
                      I tracked down this issue to where I noticed it happens only when the browser is closed while maximized -- thus after starting maximized, RR resizes it and then the browser itself re-adjusts itself.. the fix was to restore the window state of the browser before embbeding it.. it worked on my tests.. I guess I'll have to add something to check if it is out of place afterwards..
                        Thanks :d
                          Still having the problem too. Just an FYI
                          Live mp3Car Facebook Chat
                            What browser are you guys using ? I.E. or FireFox ??
                              I am using I.E.
                              What I ended up doing for now was not using the maxamize button Insted I just stretched the screen as big as it would go by draging the corner of the window.(looks like it is maxamized) as long as I leave it like that it works perfect.It only gets messed up if the browser is maxamized when closed.
                              1.)Orion 2500d Amp
                              1.)Orion 15" h2 Sub
                              1.)Orion 8004 Amp
