How hard would this be to do? - Button to copy text box contents to a file
  • How hard would this be to do? - Button to copy text box contents to a file
    I would love to add a button to the search screen that would allow me to copy the current contents of the search text box as a new line of text to a text file called "Songs to DL.Txt" how hard is this? Basically, after I search for a song that I find is not in my directory, I could hit a button that would add the search string to a list of songs that I need to download to remind me later. Example, I type U2 Beautiful day, it's not found, I hit a button "AddList" and the string "U2 Beautiful day" gets added as a line to the text file "Songs to DL.TXT"
    Its not the cards you're dealt, its how you play the hand!
    Originally posted by ryuandwings
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    That shouldn't be too diffacult for the author, you may want to write it to an XML file instead of a txt because it can be more scalable.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
      Bump
      Please help.
        If I am to work on anything like this, I think I would just make a "history" of searches, to where you could press a button and display "N" recent searches to select and search with ..
        Ride Runner RR's Myspace
          I guess that might be usefull too. Never thought about that.
          Maybe I'll try to figure out how to do what I wanted to do on my own. One question: When we use commands in the skin editor like "Audio" and "Exit", where are those commands defined? IN other words, those are links to vb code written correct? So if I were to design my own command like "Savetofile" where would I actually code this?
          Thanks Guino.
          Please help.
            Just search for "backspace" add the below right before it:
            case "savetofile"
            t = freefile
            open "c:\saved.txt" for append as #t
            print #t, frm.txt(0).text
            close #t
            that should work (although I haven't tried) as long as you call "savetofile" from the OSK window... now, to make this work with settings from rr.ini and such there's a whole shebang needed...
              OK, thats a good start. I actually understand whats going on there. I know a lot of simple VB. OK, I have the source code on my home PC as well as VB 6.0. I assume you are referring to the CASE "Backspace" in ModRoadRunner?
              Oh, and you lost me with the settings from RR.INI being a problem.
              Thank you very much, Guino.
              Please help.
                yeah, that case "backspace" is the only place with such word in the source.. just place the code right above it and you're done.. What I meant was that You could make RR read a setting from RR.INI to tell which file to save data to.. but this requires more changes..
                  Oh, it'll be fine to do it in the code. First thing I've got to do though is figure out which libraries I am missing because when I load the VBP file and try to run I get compiler errors that the libraries are not found. I'm looking into this now.
                  Please help.
                    Once I get my libraries in order, let me ask you this.
                    I add the case for "Savetofile". Understood.
                    Now, to trigger that to happne in the program, do I just have to make a button in the Searchbrowser.skin that has the code "Savetofile" and it'll work?
                    Please help.
                      You'll have to make a button to execute "SAVETOFILE" yes, but it has to be on the OSK screen!! (where the text you want to save is at)...
                        Yeah I figured as much. I am using Alpine Amber Skin so it will be on the SearchBrowser screen. Thanks.
                        Please help.
