RR 07-15-05... More improvements..
  • RR 07-15-05... More improvements..
    In this version:
    -Added Functional Mode command support (button functions based on fm/xm/mm mode)
    -Added support for Temperature and Voltage readings from same serial port
    -Added Auto-reconnect GPS function (prevention)
    -Added support for switching button commands
    -Added support for controlling volume of any Audio line using buttons and sliders
    -Added support for mute indicators for any Audio line
    -Added INI option to close running embbeded applications upon exit of RR
    -Added Dynamic Equalizer Boost support
    -Improved skin resizing to be of higher quality with anti-aliasing
    -Fixed issue with centering menus when using X/Y skin position
    -Fixed issue with AVS/MilkDrop displacement when using X/Y skin position
    -Fixed issue with clipping screen when using X/Y skin position
    -Fixed issue with slider pointer trail in 7/3 version
    -Fixed fonts on RR/RRConfig to "western" charset
    -Fixed Mute/Unmute Issue with unusual audio input lines
    -Fixed Issue with "negative" memory readings
    -Added dynamic Labels Preview to SkinEditor
    -Fixed Issue with SkinEditor giving errors when "canceling" font/color selection
    -Fixed Issue with "Duplicate" function of skin editor
    -Fixed Issue with SkinEditor adding "skin" to the screen name when saving skin
    -Fixed Issue with SkinEditor's "copy skin" function
    -Changed Skin Editor to display menu.skin automatically when loading a skin
    Notes:
    Some of those fixes have been posted before as a "patch"...
    Look at DynEQ.ini for details on EQ Boost feature.
    Look at Skin commands.txt for new definitions.
    To close embbeded apps when exiting RR add to RR.INI: closeapps=true
    Thanks for your support,
    Guino.
    Ride Runner RR's Myspace
    Thanks for the update. Glad to see SkinEditor get a tune-up
    Beer is proof that God loves us and wants us to be happy Benjamin Franklin
      Sounds cool. Lots of improvements in that list that sound very intriguing!
        thanks for the update appreciate em.
          You da man!
          Athlon XP 1900+, FIC AT31 Radeon IGP320, 256MB PC2100, Toshiba/IBM 7.2K 180GB HD,
          Sony XA-300 USB Audio -> Sony CDA-M600 HU, Integrated TV-Out -> Lilliput 7" Widescreen TV (CRAP),
          Vector 700 Watt Inverter, USB Keypad Control, Windows XP SP2, RoadRunner
            Cool, thanks for the update
            Plan for project = 100%
            Part the project. = 100%
            Built...................= 99%
            Finish.................= 99%
            Install ...............= 99% -50%
            Ditail at 4u2n.dk
            Here
              Very nice! Guino, any chance we can support launching win32 java files in the upcomming future?
              Mark
              Website: http://www.greenpowerenthusiast.com/
              Car'Puter Project
              - Xenarc 700TSV
              - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
              - 1x 256MB Corsair XMMS DDR400
              - M2-ATX
              - Belkin 802.11G W-Nic
              - Garmin 15H GPS
              - WinXP SP2 (NLited)
                In this new release I have found 2 small problems:
                1) with the radio D-Link doesn't visualize anymore the writing "stereo" when the station radio transmits stereo.
                2) the volume with the radio D-Link drastically goes down of power in comparison to I listen to some audio player, using the same percentage of settings.
                Tested a will with and without new function of DinEQ, these problems remain.
                In RR config utility I have set the "Master control volume"
                Mauri
                  Mauri
                  I have not changed anything with the DLink radio for the longest times.. you probably just placed the Dlink folder under RR's directory and that activates the "NEW" DLink driver -- the new driver does not support the stereo indicator NOR the "seek" functions (But it doesn't crash on 2000/XP).. If you wish to restore the old driver, you'll need to copy usbradio.sys from the DLink folder over the one in your windows\system32 folder, then rename or delete the dlink folder.
                    You can probably do this by running "java <appname>" or whatever -- you'll probably need to include the full path of java.exe and for the application.. I've done this from VB before.. it might be easier to run a .BAT file with all the pathnames and parameters correctly (since java is a ***** when it comes to requiring parameters for libraries and such)...
                      Thanks Guino!!!
                      4G64 5 SPEED
                      MY CAR - MY 5SPD - MY CARPUTER - MY GARAGE SALE
                        Good job - Ive not even had time to test the temporary unload fix and already its added to the ini file as an option... im impressed
                          Can't say anything other than "You are da Man!!"
                          I just thought about one option that I or many might like, shouldn't be too hard to do?
                          Somewhere/somehow we could put a resume vol setting...cause I usally always turn it down to the same percent.
                          You know, just like some car radios, that you can set the turn on vol setting...TIA
                          Keep up the great update...I'll have to make another donation...
                          Next in line: RRMedia v2.0
                          DFX 5.1.1 Skin
                          Appstore Link
                          My RideRunner Plugins
                          RRMedia
                          RRExtended
                          DFXVoice
                            How does the GPS reconnect work?? I'm assuming this is for use with hibernation. Do I have to set which port my GPS is plugged into?
                            Progress Meter:
                            [|||||!||||'] 95% complete
                            It's in... it's finally installed!!!! But never finished!
                            "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
                              Great job Guino
                              Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
                              Software: Roadrunner, Mapmonkey/Freedrive
                              My Car PC project
                              FD & MM voices
