Problems with Videoplayer.
  • Problems with Videoplayer.
    Help!! My videoplayer gives me problems.
    I've checked everything 20x and I can't see what goes wrong. As a base for the .skin files I used the files from the Zots'05 skin and edited it to suit my buttons.
    The problems:
    - Video_Player won't play the movie I have selected in the Video-Brower, but always starts with the first movie in the movie folder.
    - If I press Select All in the Videobrowser the screen goes back to the main menu.
    - If I press play in the Videobrowser it won't start playing a movie untill I select "Next"
    Video_Player:
    Code:
    MEDIACAR Skin
    MEDIACAR Default"Videoplayer"skinskinskinskinskinskinskinskin skin
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B02,403,89,146,76,"VOL-","Volume-"
    B01,553,89,146,74,"VOL+","Volume+"
    B11,253,89,146,76,"LOAD;video_browser.skin","Video Playlist"
    B05,101,9,146,74,"PREV","Prev"
    B07,252,7,146,76,"STOP","Stop"
    B06,403,7,146,76,"PLAY","Play"
    B08,553,9,146,74,"NEXT","Right"
    B09,0,9,96,74,"UP","Up"
    B10,704,9,96,74,"DOWN","Down"
    B12,101,89,146,74,"EXIT","Exit"
    /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
    S01,144,82,508,10,221,28,508,10,H,01,"zd_slider3\pointer3.gif",12,"VIDEOPOS",""
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L07,220,175,150,020,255,255,255,18,"Arial Narrow:B","TIME","Time"
    L08,220,200,150,020,255,255,255,18,"Arial Narrow:B","DATE","Date"
    END
    Video Browser:
    Code:
    MEDIACAR Skin
    MEDIACAR F-CNS800x600(Stretched)"Audiobrowser"skinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskinskin skin
    video_browser_off.jpg,video_browser_off.jpg,video_browser_on.jpg,video_browser_down.jpg
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S,206,304,388,218,255,255,255,0,0,0,0,0,255,0,0,255,0,255,255,1,14,"Verdana"
    B,23,299,146,74,"CLEARLIST","Clearlist"
    B,23,138,134,74,"ADD1","add1"
    B,23,49,146,85,"EXIT",""
    B05,23,453,146,85,"VIDEO","Exit"
    B09,631,49,146,85,"PGUP","Page UP"
    B08,643,138,134,74,"UP","Up"
    B,23,215,146,74,"SELECT+","Select+"
    B03,631,215,146,74,"BACK","Back"
    B04,631,299,146,74,"BROWSE","Browse"
    B,23,376,134,74,"MINUS1","Delete"
    B07,643,376,134,74,"DOWN","Down"
    B06,631,453,146,85,"PGDOWN","Page DOWN"
    /, S, x, y, w, h, fore R;RGB, G, B,  back R;RGB, G, B,  folder R;RGB, G, B,  file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, font name
    S01,366,67,228,218,255,255,255,000,000,000,255,255,255,255,255,255,0,0,255,0,255,255,1,14,"Verdana"
    /, J, x, y, w, h
    J01,206,67,155,218
    END
    For testing I copy my skin into the Zots'05 folder and overwrite with my new files. This works for every screen exept the video player.
    How can I make the videoplaylist / player work correctly?
    You should start the video player with the "VIDEO" command... you should load the file browser with the "LIST" command.. you should use "EXIT" to exit the video browser and the video player... try that and if it doesn't work, post a debug log file (add debugmode=true to RR.INI, run it, try again and exit).
    Ride Runner RR's Myspace
      I've checked all the commands & tooltips, after some changes all seem to point to the right place now, but the error still remains.
      Code:
      18-07-05 19:58:37: Start
      18-07-05 19:58:37: Master Vol: Master Volume/4
      18-07-05 19:58:37: GetLineControl Failed: 401
      18-07-05 19:58:37: No Treble Support
      18-07-05 19:58:37: No Bass Support
      18-07-05 19:58:37: Source: Wave=&H1008/1
      18-07-05 19:58:37: Source: SPDIF=&H1000/2
      18-07-05 19:58:37: Source: MIDI=&H1004/3
      18-07-05 19:58:37: Source: Aux=&H100A/4
      18-07-05 19:58:37: Source: Video=&H100A/5
      18-07-05 19:58:37: Source: CD Audio=&H1005/6
      18-07-05 19:58:37: Source: Line In=&H1002/7
      18-07-05 19:58:37: Source: Microphone=&H1003/8
      18-07-05 19:58:37: Source: Phone=&H1006/9
      18-07-05 19:58:37: Source: PC Speaker=&H100A/10
      18-07-05 19:58:37: Can't Open Source
      18-07-05 19:58:37: No Mute for Source
      18-07-05 19:58:37: Winamp window not found.
      18-07-05 19:58:41: Shell: "C:\Program Files\Winamp\winamp.exe"
      18-07-05 19:58:41: Sim.WMSGs: 1
      18-07-05 19:58:41: Sim.WMSGs: 2
      18-07-05 19:58:43: Executing: LOAD;VIDEO_BROWSER.SKIN
      18-07-05 19:58:51: Executing: ADD1
      18-07-05 19:58:55: Executing: VIDEO
      18-07-05 19:58:58: Executing: PLAY
      18-07-05 19:58:58: MCI Play Error: 263     <---My problem?!?
      18-07-05 19:59:03: Executing: PLAY
      18-07-05 19:59:03: MCI Play Error: 263
      18-07-05 19:59:08: Executing: DOWN
      18-07-05 19:59:13: Executing: EXIT
      18-07-05 19:59:14: Executing: EXIT
      18-07-05 19:59:15: Executing: EXITMENU
      18-07-05 19:59:16: Executing: EXIT
      18-07-05 19:59:17: Winamp window not found.     <--Part of problem?
      18-07-05 19:59:17: Shutdown
        Your problem is simple: you're trying to load the video browser WITHOUT going through the VIDEO PLAYER.. this basically prevents RR from handling music propperly (to stop it) and that likely prevents the video player from working propperly.. If you launch the video PLAYER and THEN the video browser, it should work.
          Yeh that solved it, thanks again!
            Can't I have a filelist in the video browser? I've defined it the same way as the music browser but it doesn't seem to work.
              It is the basically same thing .. only playlists don't work for video (yet)..
                Sorted, thanks!
