Control RR from VB.NET
  • Control RR from VB.NET
    Im about to write an app to send some controls to RR, but I cant really get it to work, Ive checked the example in the source but it is VB6. Is there anyone here who can translate that into VB.NET?
    Any luck with VB.Net yet?
      thought of converting? vb6 to vb .net
        ummm.... I chose not to use .NET for multiple reasons... in any case, as long as you can send the commands using the SendMessage/COM hooks API, you should be able to do it... I believe that 'Garo' has code he made for integrating his .NET GPS application with RR.
        Ride Runner RR's Myspace
          I actually wrote a .dll file that I can call from an .NET app. I can share it when I get back home.
            I would like this dll if you can post it. Im working on some GPS stuff, voice command stuff, two way radio stuff...etc and may want to import it into RR.
            Um, I guess this is where you put something witty.WITTY
            My Web site, in the design stage. http://home.comcast.net/~cstrachn
            Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
              Here is the dll file and a VB.NET example
                I haven't found out how to pull info from FreeDrive if it's embedded in RR, if you do please share it.
