MapMonkey too low down on the screen
  • MapMonkey too low down on the screen
    Guys,
    Most of the time when I fire up Map Monkey in RR, the MM is too low down in the RR GPS window (Standard skin). It means I can't press the menu button, and have to exit RR and use MM outside of RR to enter a destiniation, and then re-load RR, and then MM.
    Any ideas?
    Read the GPS FAQ... likely, MM and RR are "fighting" to define the window position.. but you can play around with the startup setting on MM to fix this..
    Ride Runner RR's Myspace
      That sorted it. The y co-ord was set to -56 for some reason.
      Cheers Guino
