Phoco and RR (again)
  • Phoco and RR (again)
    OK I have searched and my head is spinning like one of Ildena's flash logos with all the threads on RR and Phoco.
    I have a registered 1.4.5.29756 copy of Phoco, runinng RR 25/07 and BMV2 skin.
    phone works Ok with Phoco on it's own and if I use HyperTerminal I can connect to Phoco, however RR does not seem to talk to it at all.
    I have tried having RR start Phoco with both the remotedesign checked and uncheck, I have tried running phoco first checking it's connected and then running RR.
    Here is a copy of the phoco part of my rr.ini
    Code:
    phocopath=C:\Program Files\PhoneControl.NET\PhoneCtl.NET.exe
    addressfile=
    callsfile=
    ringtone=C:\WINNT\Media\notify.wav
    standardphonebook=1
    maxcalllistentries=100
    What have I missed?
    Also a copy of my phoneCTRL log
    Code:
    28/07/2005 13:43:23 	MediaPlayer: WMPLAYER
    28/07/2005 13:43:23 	Version: 1.4.5.29756
    28/07/2005 13:43:24 	KeyMaps\Keypad.KeyMap.xml not found content is misspelled!!
    28/07/2005 13:43:24 	SMS templates loaded, 5 templates found.
    28/07/2005 13:43:24 	Opening COM1
    28/07/2005 13:43:24 	COM: >ATE1
    28/07/2005 13:43:39 	**** TIMEOUT ****
    28/07/2005 13:43:40 	COM: >AT+CSCS="8859-1";+CRC=1;+CLIP=1;+CNMI=2,1
    28/07/2005 13:43:40 	COM: <
    OK
    28/07/2005 13:43:41 	COM: >AT+COPS?
    28/07/2005 13:43:41 	COM: <
    +COPS: 0,2,23433
    OK
    28/07/2005 13:43:41 	Current operator: 23433
    28/07/2005 13:43:41 	COM: >AT+CGSN
    449333204341493
    OK
    28/07/2005 13:43:41 	COM: >AT+GMI
    Nokia Mobile Phones
    OK
    28/07/2005 13:43:41 	Real vendor: [Nokia Mobile Phones]
    28/07/2005 13:43:41 	COM: >AT+CSQ;+CBC
    +CSQ: 31,99
    +CBC: 0,70
    OK
    side note RR does not close phoco down.
    Is this Phoco log made when running Phoco INSIDE or OUTSIDE RR ? .. my best guess on this type of issue is that you may have set some COM port in RR to the same port as Phoco and then Phoc can't open the same port, but if that was the case, phoco would work if launched before RR.. You don't een get the signal/battery levels in RR ?
    Ride Runner RR's Myspace
      Inside. (will get a log for both)
      Not sure what COM port I could set in RR. The GPS is set to COM 0 as I have not got the GPS connected (testing on work PC) but I have not configured RR to use any COM ports.
      No signal or battery levels at all.
      I turned the debug mode on and got a debug.txt file
      Code:
      28/07/2005 16:09:25: Start
      28/07/2005 16:09:25: Master Vol: Volume Control/4
      28/07/2005 16:09:25: GetLineControl Failed: 401
      28/07/2005 16:09:25: No Treble Support
      28/07/2005 16:09:25: No Bass Support
      28/07/2005 16:09:25: No Master ON/OFF
      28/07/2005 16:09:25: Source: Wave=&H1008/1
      28/07/2005 16:09:25: Source: SW Synth=&H1004/2
      28/07/2005 16:09:25: Source: CD Player=&H1005/3
      28/07/2005 16:09:25: Source: Microphone=&H1003/4
      28/07/2005 16:09:25: Source: Line In=&H1002/5
      28/07/2005 16:09:25: Winamp window not found.
      28/07/2005 16:09:25: Shell: "C:\Program Files\Winamp\winamp.exe"
      28/07/2005 16:09:37: Executing: AUDIO
      28/07/2005 16:09:38: Sim.WMSGs: 1
      28/07/2005 16:09:38: Sim.WMSGs: 2
      28/07/2005 16:09:42: Executing: MAIN
      28/07/2005 16:09:44: Executing: LOAD;communication.skin
      28/07/2005 16:09:46: Executing: PHOCO
      28/07/2005 16:09:54: Executing: reload
      28/07/2005 16:10:01: Executing: hangup_call_phoco
      28/07/2005 16:10:02: Executing: dial_phoco
      28/07/2005 16:10:03: Executing: showphonelist
      28/07/2005 16:10:05: Executing: reload
      28/07/2005 16:10:07: Executing: EXIT
      28/07/2005 16:10:08: Executing: EXIT
      28/07/2005 16:10:09: Executing: EXIT
      28/07/2005 16:10:10: Winamp window not found.
      28/07/2005 16:10:10: Shutdown
      28/07/2005 16:21:21: Start
      28/07/2005 16:21:22: Master Vol: Volume Control/4
      28/07/2005 16:21:22: GetLineControl Failed: 401
      28/07/2005 16:21:22: No Treble Support
      28/07/2005 16:21:22: No Bass Support
      28/07/2005 16:21:22: No Master ON/OFF
      28/07/2005 16:21:22: Source: Wave=&H1008/1
      28/07/2005 16:21:22: Source: SW Synth=&H1004/2
      28/07/2005 16:21:22: Source: CD Player=&H1005/3
      28/07/2005 16:21:22: Source: Microphone=&H1003/4
      28/07/2005 16:21:22: Source: Line In=&H1002/5
      28/07/2005 16:21:22: Winamp window not found.
      28/07/2005 16:21:22: Shell: "C:\Program Files\Winamp\winamp.exe"
      28/07/2005 16:21:34: Executing: AUDIO
      28/07/2005 16:21:35: Sim.WMSGs: 1
      28/07/2005 16:21:35: Sim.WMSGs: 2
      28/07/2005 16:21:46: Executing: CTRLDOWN
      28/07/2005 16:21:47: Executing: CTRLDOWN
      28/07/2005 16:21:48: Executing: CTRLDOWN
      28/07/2005 16:21:49: Executing: CTRLDOWN
      28/07/2005 16:21:49: Executing: CTRLUP
      28/07/2005 16:21:50: Executing: CTRLUP
      28/07/2005 16:21:51: Executing: CTRLDOWN
      28/07/2005 16:21:54: Executing: MAIN
      28/07/2005 16:21:56: Executing: LOAD;communication.skin
      28/07/2005 16:21:58: Executing: PHOCO
      28/07/2005 16:22:02: Executing: reload
      28/07/2005 16:22:05: Executing: reload
      28/07/2005 16:22:10: Executing: dial_phoco
      28/07/2005 16:22:11: Executing: dial_phoco
      28/07/2005 16:22:12: Executing: dial_phoco
      28/07/2005 16:22:15: Executing: dial_phoco
      28/07/2005 16:22:16: Executing: dial_phoco
      28/07/2005 16:22:19: Executing: hangup_call_phoco
      28/07/2005 16:22:20: Executing: hangup_call_phoco
      28/07/2005 16:22:22: Executing: hangup_call_phoco
      28/07/2005 16:22:23: Executing: hangup_call_phoco
      28/07/2005 16:22:26: Executing: hangup_call_phoco
      28/07/2005 16:22:29: Executing: reload
      28/07/2005 16:22:30: Executing: showphonelist
      28/07/2005 16:22:32: Executing: showsimlist
      28/07/2005 16:22:33: Executing: showdialedcalls
      28/07/2005 16:22:34: Executing: showreceivedcalls
      28/07/2005 16:22:35: Executing: showmissedcalls
      28/07/2005 16:22:35: Executing: reload
      28/07/2005 16:22:48: Executing: reload
      28/07/2005 16:22:49: Executing: EXIT
      28/07/2005 16:22:51: Executing: MENU;volume.skin
      28/07/2005 16:22:53: Executing: CANCEL
      28/07/2005 16:22:54: Executing: EXIT
      28/07/2005 16:22:55: Executing: EXIT
      28/07/2005 16:22:55: Winamp window not found.
      28/07/2005 16:22:55: Shutdown
      28/07/2005 16:26:43: Start
      28/07/2005 16:26:43: Master Vol: Volume Control/4
      28/07/2005 16:26:43: GetLineControl Failed: 401
      28/07/2005 16:26:43: No Treble Support
      28/07/2005 16:26:43: No Bass Support
      28/07/2005 16:26:43: No Master ON/OFF
      28/07/2005 16:26:43: Source: Wave=&H1008/1
      28/07/2005 16:26:43: Source: SW Synth=&H1004/2
      28/07/2005 16:26:43: Source: CD Player=&H1005/3
      28/07/2005 16:26:43: Source: Microphone=&H1003/4
      28/07/2005 16:26:43: Source: Line In=&H1002/5
      28/07/2005 16:26:43: Winamp window not found.
      28/07/2005 16:26:44: Shell: "C:\Program Files\Winamp\winamp.exe"
      28/07/2005 16:26:56: Executing: AUDIO
      28/07/2005 16:26:56: Sim.WMSGs: 1
      28/07/2005 16:26:56: Sim.WMSGs: 2
      28/07/2005 16:27:08: Executing: MAIN
      28/07/2005 16:27:09: Executing: LOAD;communication.skin
      28/07/2005 16:27:11: Executing: PHOCO
      28/07/2005 16:27:14: Executing: reload
      28/07/2005 16:27:20: Executing: hangup_call_phoco
      28/07/2005 16:27:21: Executing: dial_phoco
      28/07/2005 16:27:34: Executing: dial_phoco
      28/07/2005 16:27:36: Executing: hangup_call_phoco
      28/07/2005 16:27:37: Executing: dial_phoco
      28/07/2005 16:27:38: Executing: hangup_call_phoco
      28/07/2005 16:27:42: Executing: reload
      28/07/2005 16:27:47: Executing: MENU;volume.skin
      28/07/2005 16:27:48: Executing: VOL+
      28/07/2005 16:27:49: Executing: VOL+
      28/07/2005 16:27:50: Executing: MASTERMUTE
      28/07/2005 16:27:51: Executing: VOL-
      28/07/2005 16:27:52: Executing: VOL-
      28/07/2005 16:27:52: Executing: MASTERMUTE
      28/07/2005 16:28:03: Executing: CANCEL
      28/07/2005 16:28:13: Executing: EXIT
      28/07/2005 16:28:14: Executing: EXIT
      28/07/2005 16:28:16: Executing: EXIT
      28/07/2005 16:28:16: Winamp window not found.
      28/07/2005 16:28:16: Shutdown
        OK here is the phonectrl on it's own no RR
        Code:
        29/07/2005 11:21:20 	MediaPlayer: WMPLAYER
        29/07/2005 11:21:20 	Version: 1.4.5.29756
        29/07/2005 11:21:22 	Keymap "Sample Key-Map for SE T610 simulating a mobile phone like keypad" loaded, 25 mappings found.
        29/07/2005 11:21:22 	SMS templates loaded, 5 templates found.
        29/07/2005 11:21:22 	Opening COM1
        29/07/2005 11:21:22 	COM: >ATE1
        29/07/2005 11:21:37 	**** TIMEOUT ****
        29/07/2005 11:21:38 	COM: <
        OK
        29/07/2005 11:21:38 	COM: >AT+CSCS="8859-1";+CRC=1;+CLIP=1;+CNMI=2,1
        29/07/2005 11:21:38 	COM: >AT+COPS?
        +COPS: 0,2,23433
        OK
        29/07/2005 11:21:39 	Current operator: 23433
        29/07/2005 11:21:39 	COM: >AT+CGSN
        29/07/2005 11:21:39 	COM: <
        <phone number>
        OK
        29/07/2005 11:21:39 	COM: >AT+GMI
        Nokia Mobile Phones
        OK
        29/07/2005 11:21:39 	Real vendor: [Nokia Mobile Phones]
        29/07/2005 11:21:39 	COM: >AT+CSQ;+CBC
        +CSQ: 31,99
        +CBC: 0,70
        OK
        29/07/2005 11:22:09 	Callers photo not found!
        29/07/2005 11:22:09 	COM: >ATD<phone number>;
        29/07/2005 11:22:23 	COM: <
        OK
        29/07/2005 11:22:31 	COM: >AT+CHUP
        29/07/2005 11:22:31 	COM: <
        OK
        29/07/2005 11:22:48 	COM: <
        OK
        29/07/2005 11:22:48 	COM: >AT+CPBS="ME"
        29/07/2005 11:22:48 	COM: >AT+CPBR=?
        29/07/2005 11:22:49 	COM: <
        +CPBR: (1-500),48,50
        OK
        29/07/2005 11:22:49 	COM: >AT+CPBR=1,500
        29/07/2005 11:22:55
        <here was a lsit of numbers I have removed>
        OK
        29/07/2005 11:23:16 	SwitchToApp not running. Closing.
          Phoco loaded first followed by RR
          Code:
          29/07/2005 11:29:58 	MediaPlayer: WMPLAYER
          29/07/2005 11:29:58 	Version: 1.4.5.29756
          29/07/2005 11:29:59 	Keymap "Sample Key-Map for SE T610 simulating a mobile phone like keypad" loaded, 25 mappings found.
          29/07/2005 11:29:59 	SMS templates loaded, 5 templates found.
          29/07/2005 11:29:59 	Opening COM1
          29/07/2005 11:29:59 	COM: >ATE1
          29/07/2005 11:30:15 	**** TIMEOUT ****
          29/07/2005 11:30:15 	COM: >AT+CSCS="8859-1";+CRC=1;+CLIP=1;+CNMI=2,1
          29/07/2005 11:30:15 	COM: <
          OK
          29/07/2005 11:30:15 	COM: >AT+COPS?
          +COPS: 0,2,23433
          OK
          29/07/2005 11:30:15 	Current operator: 23433
          29/07/2005 11:30:15 	COM: >AT+CGSN
          <phone number>
          OK
          29/07/2005 11:30:16 	COM: >AT+GMI
          29/07/2005 11:30:16 	COM: <
          Nokia Mobile Phones
          OK
          29/07/2005 11:30:16 	Real vendor: [Nokia Mobile Phones]
          29/07/2005 11:30:19 	COM: >AT+CSQ;+CBC
          29/07/2005 11:30:19 	COM: <
          +CSQ: 31,99
          +CBC: 0,50
          OK
          29/07/2005 11:30:29 	COM: <
          OK
          29/07/2005 11:30:29 	COM: >AT+CPBS="ME"
          29/07/2005 11:30:29 	COM: >AT+CPBR=?
          OK
          29/07/2005 11:30:29 	COM: >AT+CPBR=1,500
          29/07/2005 11:30:35 	COM: <
          <list of phone numbers deleted>
          OK
          29/07/2005 11:30:36 	SavePhonebook failed!
           System.NullReferenceException: Object reference not set to an instance of an object.
             at PhoneCtl.NET.frmMain.SavePhonebook(Int32 pi_iPBIndex)
          List of numbers was got when I pressed the reload button inphoco not RR
            And finally with RR starting phoco
            Code:
            29/07/2005 11:48:51 	MediaPlayer: WMPLAYER
            29/07/2005 11:48:51 	Version: 1.4.5.29756
            29/07/2005 11:48:52 	KeyMaps\Keypad.KeyMap.xml not found content is misspelled!!
            29/07/2005 11:48:52 	SMS templates loaded, 5 templates found.
            29/07/2005 11:48:52 	Opening COM1
            29/07/2005 11:48:52 	COM: >ATE1
            29/07/2005 11:49:07 	**** TIMEOUT ****
            29/07/2005 11:49:08 	COM: >AT+CSCS="8859-1";+CRC=1;+CLIP=1;+CNMI=2,1
            29/07/2005 11:49:08 	COM: <
            OK
            29/07/2005 11:49:08 	COM: >AT+COPS?
            +COPS: 0,2,23433
            OK
            29/07/2005 11:49:08 	Current operator: 23433
            29/07/2005 11:49:08 	COM: >AT+CGSN
            <phone number>
            OK
            29/07/2005 11:49:09 	COM: >AT+GMI
            29/07/2005 11:49:09 	COM: <
            Nokia Mobile Phones
            OK
            29/07/2005 11:49:09 	Real vendor: [Nokia Mobile Phones]
            29/07/2005 11:49:09 	COM: >AT+CSQ;+CBC
            +CSQ: 31,99
            +CBC: 0,50
            OK
              And finally rr debug log
              Code:
              /07/2005 11:48:45: Start
              29/07/2005 11:48:45: Master Vol: Volume Control/4
              29/07/2005 11:48:45: GetLineControl Failed: 401
              29/07/2005 11:48:45: No Treble Support
              29/07/2005 11:48:45: No Bass Support
              29/07/2005 11:48:45: No Master ON/OFF
              29/07/2005 11:48:45: Source: Wave=&H1008/1
              29/07/2005 11:48:45: Source: SW Synth=&H1004/2
              29/07/2005 11:48:45: Source: CD Player=&H1005/3
              29/07/2005 11:48:45: Source: Microphone=&H1003/4
              29/07/2005 11:48:45: Source: Line In=&H1002/5
              29/07/2005 11:48:45: Winamp window not found.
              29/07/2005 11:48:46: Shell: "C:\Program Files\Winamp\winamp.exe"
              29/07/2005 11:49:07: Executing: AUDIO
              29/07/2005 11:49:08: Sim.WMSGs: 1
              29/07/2005 11:49:49: Executing: EXIT
              29/07/2005 11:49:50: Executing: PHOCO
              29/07/2005 11:49:58: Executing: reload
              29/07/2005 11:50:04: Executing: showphonelist
              29/07/2005 11:50:04: Executing: showsimlist
              29/07/2005 11:50:05: Executing: showdialedcalls
              29/07/2005 11:50:05: Executing: showreceivedcalls
              29/07/2005 11:50:06: Executing: showmissedcalls
              29/07/2005 11:50:07: Executing: reload
              29/07/2005 11:50:10: Executing: 0
              29/07/2005 11:50:10: Executing: 7
              29/07/2005 11:50:11: Executing: 8
              29/07/2005 11:50:12: Executing: 4
              29/07/2005 11:50:12: Executing: 1
              29/07/2005 11:50:13: Executing: 2
              29/07/2005 11:50:14: Executing: 8
              29/07/2005 11:50:14: Executing: 7
              29/07/2005 11:50:14: Executing: Number_MANUAL_PHOCO
              29/07/2005 11:50:14: Queued: "menu;call_out.skin"
              29/07/2005 11:50:14: Queued: "PAUSE"
              29/07/2005 11:50:14: Queued: "PRESET;OFFCALL"
              29/07/2005 11:50:14: Queued: "PRESET;PHOCO"
              29/07/2005 11:50:14: Executing: menu;call_out.skin
              29/07/2005 11:50:15: Queued:
              29/07/2005 11:50:15: Executing: PAUSE
              29/07/2005 11:50:15: Executing: PRESET;OFFCALL
              29/07/2005 11:50:15: Executing: PRESET;PHOCO
              29/07/2005 11:50:26: Executing: HANGUP_CALL_PHOCO
              29/07/2005 11:50:26: Queued: "PRESET;OFFCALL||RESUME"
              29/07/2005 11:50:26: Queued: "EXIT"
              29/07/2005 11:50:26: Executing: PRESET;OFFCALL
              29/07/2005 11:50:26: Executing: EXIT
              29/07/2005 11:50:26: Executing: RESUME
              29/07/2005 11:50:28: Executing: exit
              29/07/2005 11:50:30: Executing: EXIT
              29/07/2005 11:50:30: Winamp window not found.
              29/07/2005 11:50:30: Shutdown
              29/07/2005 11:52:52: Start
              29/07/2005 11:52:52: Master Vol: Volume Control/4
              29/07/2005 11:52:52: GetLineControl Failed: 401
              29/07/2005 11:52:52: No Treble Support
              29/07/2005 11:52:52: No Bass Support
              29/07/2005 11:52:52: No Master ON/OFF
              29/07/2005 11:52:52: Source: Wave=&H1008/1
              29/07/2005 11:52:52: Source: SW Synth=&H1004/2
              29/07/2005 11:52:52: Source: CD Player=&H1005/3
              29/07/2005 11:52:52: Source: Microphone=&H1003/4
              29/07/2005 11:52:52: Source: Line In=&H1002/5
              29/07/2005 11:52:52: Winamp window not found.
              29/07/2005 11:52:53: Shell: "C:\Program Files\Winamp\winamp.exe"
              29/07/2005 11:53:05: Executing: AUDIO
              29/07/2005 11:53:06: Sim.WMSGs: 1
              29/07/2005 11:53:06: Sim.WMSGs: 2
              29/07/2005 11:53:09: Executing: EXIT
              29/07/2005 11:53:11: Executing: TV
              29/07/2005 11:53:14: Executing: EXIT
              29/07/2005 11:53:14: TVExit: STOPPED
              29/07/2005 11:53:15: Executing: APPEARANCE
              29/07/2005 11:53:16: Executing: SKIN
              29/07/2005 11:53:19: Executing: SELECT
              29/07/2005 11:53:19: Sim.WMSGs: 1
              29/07/2005 11:53:20: Sim.WMSGs: 1
              29/07/2005 11:53:22: Executing: PHOCO
              29/07/2005 11:53:26: Executing: reload
              29/07/2005 11:54:24: Executing: reload
              29/07/2005 11:56:01: Executing: reload
              29/07/2005 11:56:02: Executing: dial_phoco
              29/07/2005 11:56:03: Executing: hangup_call_phoco
              29/07/2005 11:56:03: Executing: dial_phoco
              29/07/2005 11:56:04: Executing: dial_phoco
              29/07/2005 11:56:05: Executing: exit
              29/07/2005 11:56:05: Executing: EXIT
              29/07/2005 11:56:06: Winamp window not found.
              29/07/2005 11:56:06: Shutdown
              two instances of RR running, first with phoco already loaded second with phoco loaded by RR
                I can't seem to find a problem with those logs.. You look throgh Phoco's log and see if you find any entries of commands received from RR .. on RR's side, everything seems fine but you need to verify the screen used is phoco.skin... Hematec is working on some updates (and Zorro apparently sent him code too)... I know I need to fix it to pull up the appropriate phonebooks from the phone .. but you should be getting at least the signal and battery strength (That's automatic even without opening the phoco screen in RR).. If your phone doesn't support the "SIM" listings command, that could very well be the issue(and fixing the phonebooks to pull could fix it).
                  In phocos logs there is no sign of anything coming from RR the logs just stop are blank, unless I press buttons in phoco itself.
                  I'm using the BMV2 skin, and this is the phoco.skin file
                  Code:
                  MEDIACAR Skin
                  MEDIACAR "PhonoControl" skin
                  /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
                  B01,018,040,086,084,"showphonelist","Phonebook Handy"
                  B02,018,127,086,084,"showsimlist","Phonebook Simcard"
                  B03,018,215,086,082,"showdialedcalls","Called Numbers"
                  B04,018,300,086,083,"showreceivedcalls","Incoming Call Numbers"
                  B05,018,387,086,083,"showmissedcalls","Missed Calls"
                  B06,018,473,086,083,"reload","Reload Phonobook"
                  B07,129,512,178,082,"dial_phoco","Answer/Make Call"
                  B08,356,512,182,082,"hangup_call_phoco","Quit Call"
                  B09,546,449,247,054,"sendsms","Send SMS"
                  B10,546,392,248,058,"Number_MANUAL_PHOCO","Call"
                  B11,551,147,079,060,"1","Num 1"
                  B12,631,147,080,060,"2","Num 2"
                  B13,712,147,077,060,"3","Num 3"
                  B14,551,208,079,059,"4","Num 4"
                  B15,631,208,079,059,"5","Num 5"
                  B16,712,208,077,059,"6","Num 6"
                  B17,551,268,079,057,"7","Num 7"
                  B18,631,268,079,057,"8","Num 8"
                  B19,712,268,077,057,"9","Num 9"
                  B20,551,326,079,060,"*","Num Star"
                  B21,631,326,079,060,"0","Num 0"
                  B22,712,326,077,060,"#","Num Raute"
                  B23,128,081,415,053,"up","List Up"
                  B24,128,449,415,051,"down","List Down"
                  B25,659,515,065,080,"BACKSPACE","BACKSPACE Button"
                  B26,730,515,065,080,"exit","Back Button"
                  /, T, x, y, w, h, font color R;RGB, G, B, back color R;RGB, G, B, font size;FONT, font name, Code, tooltip
                  T01,562,092,218,038,255,255,255,000,000,000,19,"Arial Narrow:B","number_manual_PHOCO",""
                  P01,146,136,381,308,255,255,255,000,000,000,255,245,000,000,000,000,TRUE,17,"ARIAL:B"
                  /, I, x, y, w, h, Code;INDICATORCODES
                  I01,553,23,51,39,"battery_charging_phoco"
                  I02,140,25,74,42,"PHONE_CONNECTED_phoco"
                  /, Y,  Back Slider file path
                  Y01,"slider_battery\SLIDER_*.gif"
                  Y02,"slider_signal\SLIDER_*.gif"
                  /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
                  S01,685,25,77,33,685,25,77,33,V,02," ",015,"SIGNAL_STRENGTH_PHOCO","Signal Strength"
                  S02,604,34,44,19,605,34,44,19,V,01," ",015,"BATTERY_STRENGTH_PHOCO","Battery Strength"
                  END
                    This is what I get when I use hyperterminal
                    Code:
                    <PhoneControl.NET>1.4.5.29756<BatteryStatus value="70" /><SignalQuality value="3
                    <PhoneControl.NET><InCall>False</InCall></PhoneControl.NET><PhoneControl.NET>1.4.5.29756<BatteryStatus value="50" /><SignalQuality value="3
                    <PhoneControl.NET><InCall>False</InCall></PhoneControl.NET><PhoneControl.NET><InCall>False</InCall></PhoneControl.NET>
                    <PhoneControl.NET><IncomingCall name="Unknown" number="<phonenumber>" photo="C:\Program Files\PhoneControl.NET\Photos\Unknown.jpg" /></PhoneControl.NET>
                    <PhoneControl.NET><InCall>True</InCall></PhoneControl.NET>
                    <PhoneControl.NET><Connected/></PhoneControl.NET>
                      This could be the problem right here.. seems that Phoco is creating incomplete messages there.. the signal quality tag is incomplete and there's no </phonecontrol.net> tag.. unless you cut the data yourself, this would prevent RR from parsing those messages.. is that the latest Phoco ?
                        Sorry Hyperterminal seems to write over the end of the line when it has wrapped it with the next line.
                        here is the correct line
                        Code:
                        1" bars="6"/></PhoneControl.NET>
                        version is in the line above
                          Just tried sending a command from Hyperterminal to dial a number
                          Code:
                          <PhoneControl.NET>
                          <Dial number="07788414287"/>
                          </PhoneControl.NET>
                          and it worked fine.
                          Definitely seems to be a problem with RR not able to connect to Phoco through the port.
                            What port are you using in hyperterminal ? also, I hope Hyperterminal is CLOSED when you're trying to use RR.
