+1 unicode problem
  • +1 unicode problem
    If the mp3 file name is in Chinese, the +1 function will add the first 2 characters of the file name to the playlist, not showing the ID3 tag, unable to play it and skip to the next following song. Once I change the file name to English and leave the ID3 tag in Chinese, I can add the song to the playlist and everything works fine - ID3 tag is shown in Chinese and play. The select+ doesn't have this problem. Tried editing the playlist in winamp, everything works fine also.
    All I do is get the full file name and send it to winamp to be added to the playlist. I'll take a look at it but I'm unsure I can fix it.. do you have everything setup for Chines in your Regional Settings (in windows) -- what is your default unicode language setup on Control panel (not the standards and formats language, but the Unicode language) ?
    Ride Runner RR's Myspace
      The unicode is set to Chinese (HKSAR). I'm kinda sure there's nothing wrong w/ my settings. I used Media Engine b4 which has the same +1 function and it worked. I just tried Chinese (Taiwan) also, and same thing happened.
        Anyone has solved ths problem?
          sorry been busy with flight trainning, I'm building up a little todo list right now, and this is in it now...
