Sound on Click?
  • Sound on Click?
    Is it possible to have RR provide an audio "click" when pressing a button, as feedback to let you know you actually hit a button?
    I can't find this option if it exists.
    foltster
    Most touchscreens have that option already... you can simply enable it on the touchscreen settings and it will work while in RR. There's not current support for that.
    Ride Runner RR's Myspace
      If you want to get real fancy and not using the beep from the touch screen driver then use this file and place it into C:\
      You can use this command on all your buttons to play any file you want to.
      B01,145,390,120,080,"RUNW;C:\playfile.exe|C:\Music .wav||AUDIO","Audio Player"
      Get creative.
      Good luck
        For test your sw,the exact way to write for example this button\command?
        B24,000,267,75,67,"MM;Hotkey_CMD|FE_NAVMODE_TOGGLE ",000
        Mauri
          Yes, but those do not know if I have clicked a button or just clicked empty space...(or do they?)
          Get creative.
          Good luck
          This is a creative solution. I may mess with it. A little elbow grease to drop it onto all the buttons, but not a terrible solution.
