remove wire frame from winamp tv plugin ?
  • remove wire frame from winamp tv plugin ?
    unsure if I asked this last time or not, it it possible to remove the wire frame from around the tv plugin bit ? or have I just set it up wrong ?
    CdR
    Follow me on Twitter
    http://www.FreeICE.co.uk
    also while i'm asking, the tv usb Compro Videomate I'm using also has a FM radio, now with this tvplug in I can listern to it, but is it possible to have two seperate TV buttons.. so they load a different playlist.. ie.. tv channels on one and radio one on the other ?
    ta
    CdR
      The Thin Frame stays by default (if you set thin frame in the plugin).. I have not put any effort into trying to take it out..
      You can make two buttons to load different playlists by running a .BAT file that either copies or moves the playlist folders into the right position (so that RR loads the current folder with whatever playlist you selected).
      Ride Runner RR's Myspace
        yeah I was thinking on the same lines.. just wondered if there was a built in option..
        cheers :-)
        CdR
          I've tried to do a this in a bat file
          rename TV TVLIST
          rename RADIOLIST TV
          where TV folder is my list.
          The bat's work fine when RR isnt running, but when the TV module is running it doesnt work.. any ideas fella ?
          the two command lines i'm running are
          B,-1,428,88,86,"RUNQ;C:\carpc\copytv.bat||TV",
          B,-1,343,88,86,"RUNQ;C:\carpc\copyradio.bat||TV",
          CdR
            its ok.. sussed what i'm going to do.
            I will create a new skin, this will have around 10 radio buttons on, each one will link direct to the winamp radio file.. so when u click on it, it will load and jobs a good'un. I will also make it in flash, so it will display the radio name etc.. so it will all look like a stock hu. :-)
            CdR
              The problem on the bat files was likely just that you should likely give the full PATH to rename..
