MM Commands for displaying data from MM in RR
  • MM Commands for displaying data from MM in RR
    Hi!
    Where could i find some information about Map Monkey request dinamic? In the skin commands.txt i read:
    "MM" - Map Monkey request dynamic command. You can execute any Map Monkey function by providing the request command -- See Map Monkey's SDK Manual for list of commands.
    Example: "MM;View_3D" (Switches the view mode to 3D)
    Extra info that is not within Map Monkey's D3Request list:
    ETA, ETR, CITY, STREET, ZIP, SATELLITECOUNT
    but it doesnt work!
    guino, could you pass me an example about requesting the speed from MM, please!
    Thanx!
    The Brushed skins on my site use this features and it has always worked. You probably haven't read the GPS FAQ, read it and you'll know how to enable MM's info/commands to RR.
    Ride Runner RR's Myspace
      tHANKS guino!
      The port i used was wrong, now it works perfectly.
      Now, i need the full MM command list, i need:
      - speed
      - altitude
      Only another question, could it be possible make some aritmetic operations (add, multiply...) with the results of the speed (in order to know the medium speed, the max speed)
      Yet im a newbie in RR...
      Thanx again!
        sorry, you'll only be able to do thatby making a separate application that reads MM's info and provides it to RR or whatever app you want to use. The list of MM Commands can be found in the help files provided with MM.
          hi guino,
          ive investigating about the posibility of making an application on vb. Where can i find the monkeytalk dll?
          Thanks guino, for all.
          (Sorry my poor "spanglish")
            It comes with MM.. in the same folder of its help files with all the MM Commands.
              The daily logs provide info like speed, alt,lon etc....
              Thanatos.
              RexBruMet Skin for FrodoPlayer
              Nissan Aux-in MOD
              Originally posted by bgoodman
              We're an international forum, post in whatever langauge you like.
                gLUBS...
                I was working at this computer with map monkey 1.1 instead of 1.3...now i have it!
                Im planning making a new screen wich will contain:
                - Max Speed.
                - Average Speed
                - Num. Satellites
                - high
                - multimedia controls
                - Next instruction from MM
                - ETR
                - ETA
                - Current song playing
                - Next song
                It will be based on the great mmi skin
                Soon the results...
                Thanks!
