Can't Exit RR!
  • Can't Exit RR!
    I recently reinstalled windows xp to try and get my gps working.
    GPS works fine, the only issue is RR.
    opening RR is fine and it plays back fine.
    but when i try and exit by pushing the exit button, it freezes up and i can't exit.
    for some reason, if i rightclick the taskbar at the bottom that highlights RR, i get the option to close (alt+F4) and it exits fine.
    [||||||||||||||||||||] - final touches
    SUPER 7" VGA w/ TS
    Toshiba Satellite 3000
    P3 850
    256MB
    30GB
    Geforce2 Go
    DVD
    Orinoco 802.11b PCMCIA
    nlite WinXP 350MB installed
    RoadRunner
    iGuidance 2.1
    Holux GM210 GPS
    Xantrex Xpower 300
    Does this happen after the computer resumes from stand by or hibernation?
    Renault Megane...the OEM look
      from boot up
      can't figure out the problem
      it MIGHT be the updated nlite version that i just installed...
      since my last one was flawless
      SUPER 7" VGA w/ TS
      P3 850
      256MB
      30GB
      Geforce2 Go
      DVD
      RoadRunner
      iGuidance 2.1
      Holux GM210 GPS
      Xantrex Xpower 300
        Originally posted by anitanium
        from boot up
        Must be assumining you've uninstalled and reinstalled RR. I've never had this problem with RR.
          by uninstall, you mean delete the original, and reinstall from the zip file?
          SUPER 7" VGA w/ TS
          P3 850
          256MB
          30GB
          Geforce2 Go
          DVD
          RoadRunner
          iGuidance 2.1
          Holux GM210 GPS
          Xantrex Xpower 300
            By uninstall, I mean uninstall, from control panel, add/remove programs.
              after reinstalling, there is still the same problem!
              it just freezes after i click the exit button!
              this never happened before
              maybe it is my skin
              i'll try a different one and see if that helps
              SUPER 7" VGA w/ TS
              P3 850
              256MB
              30GB
              Geforce2 Go
              DVD
              RoadRunner
              iGuidance 2.1
              Holux GM210 GPS
              Xantrex Xpower 300
                turns out that the newest version doesn't like me
                using 08-08-05 right now, no problems
                SUPER 7" VGA w/ TS
                P3 850
                256MB
                30GB
                Geforce2 Go
                DVD
                RoadRunner
                iGuidance 2.1
                Holux GM210 GPS
                Xantrex Xpower 300
                  Did you make sure you have the latest flash version installed ? Flash issues can make your CPU load high and cause buttons to be unresponsive.. I'd suggest reading the whole High/CPU & Flash FAQ.
                  Ride Runner RR's Myspace
                    Have the same thing on my laptop (w2000). Checked the code it is seems to be looping in the new code that is waiting for either 5 secs of for the SAPI5 voice to be complete. I think the SAPI check is erroring and therefore not checking for the 5 secs to pass. Had no probs on my XP install.
                    Guino, If you want I can investigate a bit further.
                    My car: 2009 MAZDA CX-9 3.7L V6 runnin on LPG (Liquid Petrol Gas)
                    Hardware: None at the moment
                    Software: None at the moment
                    See: Velleman K8055 Plugin for Road Runner
                    Progress: [XXXXXXXXXX] 0 % DONE
                      Ok, found the function that is looping and why. Don't know how to fix it.
                      Problem is in function shutdown of modRoadRunner.bas ->
                      'Wait till nothing else to speak
                      If SAPI5 Then
                      t = Timer
                      While (Not VoiceObj.WaitUntilDone(1)) And Timer - t < 5
                      Sleep 100
                      If Timer < t Then t = Timer
                      Wend
                      Else
                      t = Timer
                      While VoiceObj.Speaking <> 0 And Timer - t < 5
                      Sleep 100
                      Wend
                      End If
                      The statement VoiceObj.WaitUntilDone(1) is returning error 91
                        seems like the object is already closed... there's a 5 second limit on the loop but if it errors out it won't matter.. I'll take care of it.. thanks for pointing it out.. it would be incredibly hard for me to find the problem without a computer that actually has the issue..
                        EDIT: Fixed...
                          Anytime
