Hide taskbar while navigating
  • Hide taskbar while navigating
    Hello,
    Normally I use the option to hide the taskbar automatically. When I use RR the taskbar stay's down, even when I move the mouse cursor down the screen. When I open MM and I move the cursor down the taskbar suddenly pops up. How can I prevent this? I only want to see the taskbar when I'm completely out of RR and/or MM.
    Thanks for the help
    Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
    Software: Roadrunner, Mapmonkey/Freedrive
    My Car PC project
    FD & MM voices
    Here is how I turn on and off taskbar from RR
    B33,162,397,150,63,"SHOWWINDOW;!Shell_TrayWnd;FALS E||SWITCHBUTTON;1>>SHOWWINDOW;!Shell_TrayWnd;True| |SWITCHBUTTON;1",""
    and my exit button
    "SHOWWINDOW;!Shell_TrayWnd;True||QUIT"
    2001 S10 ZR2
    Chucks Skin - to old
      If you use the Hide Task bar option, this should not be happening.. unless MM is messing with it... I'd try changing your taskbar settings (disable autohide and such)..
      Ride Runner RR's Myspace
        and my exit button
        In wich file do I need to change this setting?
        My Car PC project
        FD & MM voices
          Yes, I do use the 'hide taskbar automatic' option. But it still happens. I tried to swich the 'hide taskbar automatic' off, but then the taskbar doesn't go away at all.
          My Car PC project
          FD & MM voices
            Sounds like you've got some other application messing with your taskbar..
              I have no other apps running. I only have RR and MM running. When I deselect the option 'always show taskbar on foreground' (I have a Dutch Windows version, so I don't know the exact name) the taskbar stays away. But this is very annoying because the taskbar stays away at all other applications too.
              Do you have any idea what app causes this problem?
              My Car PC project
              FD & MM voices
                Well, that's the problem right there.. you want the taskbar to stay on top, but you don't want it to show up while MM/RR is running ?? that's a paradox my friend... basically, when there's any kind of window positioning (i.e. running applications) the task bar will probably show up.. but it is in fact weird that the hide taskbar option is not taking care of that (it is possible that the taskbar itself is making it re-appear when a new application is launched -- causing the taskbar to update).
                  Welcome to paradox
                  I guess I have to live with the option 'always show taskbar on foreground' selected.
                  I thougt that there was something wrong in the configuration of MM or RR.
                  My Car PC project
                  FD & MM voices
