Starting Phone Control takes a long time
  • Starting Phone Control takes a long time
    Hi,
    When I start RR and it says it is starting Phone Control my CPU goes 100% and it takes ~ 40 seconds for RR to start. Is this normal when using Phone Control?
    Rgds and thanks
    Ant
    Depends on your setup and if PhoCo can find your phone. AFAIK RR waits until PhoCo is fully loaded before it continues loading ==> look into your PhoCo settings
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
      Hi,
      Sorry I should have mentioned in my original post that if I start Phone Control standalone then it takes ~ 8 seconds to start and be fully functional. It only consumes the CPU and takes ~ 40 seconds during the RR start up process.
      Ant
        I think you should do some more testing.. it is UNFAIR to compare the FIRST loading time of Phoco (probably done by RR) with the NEXT loading times of phoco (either inside or outside RR)... I can guarantee you that phoco will load a whole lot faster on the 2nd, 3rd etc times.. the only reason why it takes so long to start at first is because all the .NET crap has to load up ..
        Ride Runner RR's Myspace
          Hi Guino,
          I tested this with a cold boot between each tests so as to make it as fair as possible, the results are:-
          Cold Boot -> Start Phone Control -> ~14 seconds
          Cold Boot -> Start Road Runner -> RR says Starting PC for ~40 seconds
          I watch the processes and rr.exe is consuming > 90% CPU and PhoneCTL.NET.exe uses only a few % for 2-3 seconds and nothing for the remainder of the period.
          I assume using the trial version of phone control wouldnt affect this?
          Many thanks
          Ant
            Many thanks
            Ant
            Using the trial version affects it big time, because the splash screen requires user input.
            If you search the phoco threads in the RR form you will find that the trail version is not recommended.
              Thank you for the reply, I had aready written the response when I remembered it was a trial version. Apologies, I do normally search.
              Ant
                I've noticed this too but its not the fault of Phoco or RR. My dongle just doesnt wanna immediately connect. And yes RR waits for phoco to be fully loaded before it launches itself
                Live mp3Car Facebook Chat
                  the new version will be more flexible on connecting to Phoco...
                    is it possible to have it act as if it were a normal embeded window, so say if i go to the phone screen, it loads PhoCo then and not at startup and also a close button so i can shut it down if i like without also shutting down RR.
                    beer replenishment fund
                    mp3car live search
                      it's just not practical because it takes time for phoco to initialize before you can use it.. so starting it up only when wanting to use it, would just make you wait more right when you want to use it..
