How could I display search results in a new window?
  • How could I display search results in a new window?
    I rewrote my Alpine Amber search_browser.skin to have much bigger keyboard keys for safety. However, it doesn't leave much room to display the search results. I would like to display the results in a new window, I guess a new skin. The problem is, if I use the directory list label it displays the results in full path form, IE C:\Mp3s\Songs . . .. How can I get it to display like it does in the results on the search_browser with the folder icons? I've been disecting it through the skin browser but I can't figure this one out. Read skin commands on it too.
    Its not the cards you're dealt, its how you play the hand!
    Originally posted by ryuandwings
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Why don't you replace search_browser.skin with your results screen (without a keyboard and text box), then have a searchfiles button on it ? This will bring up osk.skin and when you hit enter, the results will come up in the previous screen.. this is exactly how it happens on the audio_browser, except you get to customize the skin that display the results.
    Ride Runner RR's Myspace
      Hmmm, instead of the OSK, would I be able to use my skinned keyboard? Because that is the only reason I did this - to make the keys huge! If so, that sounds like it would be perfect idea.
      Please help.
        I'm also curious how the folder icons are displayed and what changes the properties of the that particular control - S01 if you could brieftly explain. Thanks
        Please help.
          The icons are loaded from the skin's folder (Folder.ico/gif and Media.ico/gif) there are default ones in case no images are found on the skin's folder.
          I did not understand the second part of your question.
            I do not understand the second part either.
            Did I seriously write that? Anyway, what I meant was this:
            If I opened Search_browser.skin in a text editor and then copied everything and pasted it to a new skin called results.skin, it would not display the search results. It only displays the results, formatted with folder icons, on the searchbrowser.skin screen, like it was a local control for only that screen. I was just wondering what that S01 control was if it is not a Launch list, a Directory or a playlist.
            As far as the original problem, I'm just gonna redo my OSK skin to be huge and use the search the way it works with BMV2. Thanks.
            Please help.
              I did add "extra" support for that search_browser.skin so that it would display the same as the audio_browser in order to display searched results.. It is very possible to make the results display on a Search_results.skin if present.. I would simply have to add support for it... but first I'd require a screen to test it with..
                Ok cool Just wanted to make sure there was something going on behind the scenes there. I'll think about what I'm gonna do. Thanks.
                Please help.
