question when skinning the OSK
  • question when skinning the OSK
    ok, nearly finished skinning the OSK, I have swapped afew buttons about and have added @, : , and comma.. I also want to add a WWW. button that will enter www. when pressed. I have got the @ and the : working but i'm stuck on the comma and www. below are what I have so far
    K,458,429,60,60,004,044,044,"COMMA","COMMA"
    K,157,428,60,60,004,064,064,"@","@"
    K,97,428,60,60,004,058,058,":",":"
    and
    B,-5,220,85,80,www, for www. but unsure how to go about that one..
    any ideas anyone ?
    CdR
    Follow me on Twitter
    http://www.FreeICE.co.uk
    o.. also I'm trying to add caps and shift indicator as little lights on the caps and shift buttons, but I think because of the way RR turns off the ON jpg after the button has been pressed its cancelling out the state of the indicator, is there a way round this ?
    CdR
      Your "WWW" button sir -
      K26,604,151,051,064,003,087||087||087,087||087||08 7,"W||W||W"
      Its not the cards you're dealt, its how you play the hand!
      Originally posted by ryuandwings
      Where can I get a roll of tin foil?
      I been looking for that all over the net, but I can't find it.
      Please help.
        cheers m8, will give that one a go.. just a comma and the indicators to go.. Gunio, could you add pressing the indictaors would have the same effect at the button :-)
        Also what the line (004) mean like in the below example
        cheers
        CdR
          cheers
          CdR
          Here is the comma button. I know the problem you were having. I figured out that the right ascii code along with ANY letter in the tooltip will provide a ","
          K25,552,151,052,064,003,044,044,"V"
          Don't let the V fool you. It could have been any letter.
          Please help.
            yep all working now.. thanks m8
              Hey CDR, I've thought of a silly but effective way around your little indicator problem. Check it out, heres what you do.
              Make the graphics skin so that the Light is in the button and that its light in the Whatever_on skin. Then, you make 4 buttons that turn on the feature, say shiftlock. Make the 4 buttons surround the middle of the button, leaving a square in the dead center where you light is. Then make a label for the indicator and put that label in the middle of the button over the red light. The user has no idea there are 4 identical buttons and a touch of any of the four will activate the control.
              Like this, only with just a light, it would be tighter. No chance of missing it.
              Please help.
                If your indicators are over buttons, the best thing you can do is make them blink (so they're redrawn no matter what)... otherwise, they will have to be outside the button...
                Ride Runner RR's Myspace
                  I tried my four button solution last night on my carpc and it worked like a charm.
                  Please help.
