please help with sendkey
  • please help with sendkey
    I'm trying to create a button to send alt+ctrl+t
    I've tried this still no luck
    "SENDKEY;(^%T)
    "SENDKEY;(91)
    "SENDKEY;"91"
    "SENDKEY;"^%t"
    I tried 91 because your keycode maker says alt+ctrl+t is 91 what
    am I doing wrong ?
    mp3car infill g4
    "SENDKEY;(^%T)
    "SENDKEY;(91)
    "SENDKEY;"91"
    "SENDKEY;"^%t"
    am I doing wrong ?
    Try this
    "SENDKEY;^%t","" or
    "SENDKEY;^%t"
    2001 S10 ZR2
    Chucks Skin - to old
      I tried both of them they didn't work
      mp3car infill g4
        maybe you need to activate the window
        sample
        B13,5,368,100,50,"ACTIVATE;iGuidance||SENDKEY;%f{D OWN}{DOWN}{ENTER}||GETFOCUS"
        2001 S10 ZR2
          I'm trying to make an auto it file I created work what I did was create the auto it script then made a shortcut for it and created a shortcut key alt+ctrl+t is there a better way of activating the autoit script ?
          mp3car infill g4
            Sendkey needs brackets. Try this
            "SENDKEY;{^%t}"
            You can also create an Auto it script and convert it to an exe file and call the file with the run command.
            "RUN;C:\YourFileName.exe
            Of course you have to direct the run command to the location of the file.
              ya, just right click on the autoit file and compile script then have rr run it
              sample
              B18,925,344,80,80,"RUN;C:\Program Files\Road Runner\Control\TVup.EXE",""
              2001 S10 ZR2
                I tried both and still not working
                I converted it to a exe file and put in my c drive it called ipodeject
                "RUN;C:\ipodeject.exe didn't work
                also tried "SENDKEY;{^%t}" still nothing
                mp3car infill g4
                  I copied the autoit file and put in my roadrunner folder and tried this still no luck
                  "RUN;C:\Program Files\Road Runner\ipodeject.exe
                  mp3car infill g4
                    did you put the thingy on the end
                    "RUN;C:\Program Files\Road Runner\ipodeject.exe"
                    how are you editing your skin - road runner skin editor?
                    2001 S10 ZR2
                      ok I feel stupid I left the " out at the end worked also got it to work by
                      editing the exectbl file with this
                      "ipod","RUN;c:\Program Files\Road Runner\ipodeject.exe"
                      then in my button I put in "ipod"
                      thanks for all your help
                      mp3car infill g4
