Is There An FAQ on how to use Iguidance...
  • Is There An FAQ on how to use Iguidance...
    Is There An FAQ on how to use Iguidance properly with Road Runner?
    ive seen people running it with road runner buttons and skins etc, i have tried to get it to embed using the FAQ's on GPS and Embedding, but it doesnt even fill the screen properly.
    Is there a FAQ out there on what you need to get it to run like map monkey with road runner?
    ive searched around and cant seem to find much.
    Thanks.
    you have to use skinbedder, and then set RR to external gps, set gps path to the skinbedder exe, and set gps window to the name of the skinbedder window.
    "Dude, you could like watch porn and drive at the same time with that thing."
      You don't have to use skinbedder! iGuidance will embed properly wiht RR. Go into RRConfig and click the GPS tab. Enter the following
      GPS Mode = External
      GPS Path = C:\Program Files\iNav\iGuidance\iGuidance.exe (if that's your path)
      GPS Window Name = iGuidance
      Its not the cards you're dealt, its how you play the hand!
      Originally posted by ryuandwings
      Where can I get a roll of tin foil?
      I been looking for that all over the net, but I can't find it.
      Please help.
        Yes/No...SB is not to just embed programs. It also adds buttons to make using IG or whatever program you are using more TS friendly...
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          You don't need to SB to add buttons. You can add buttons just as easily with Sendkey command.
          Please help.
            Thanks guys.
            i tried what you said J187 before posting this, and it doesnt fill the right part of the road runner window...
            i tried it with some buttons and skin files u posted in another post too, and iguidance wouldnt embed at all then...
              you don't need to use the sendkey command to add buttons, you can just use igmod.
              Dr. Ron Paul for President 2008
              Hope for America - http://www.ronpaul2008.com
              Who is Ron Paul? - Why do we need Ron Paul?
              CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
                iGmod!
                Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
                Unlimited Internet and gps tracking for $6 a month with boost mobile!
                Carputer 2: www.lmaocar.com
                  ive tried all this, but problem still lays that my iguidance wont fill the window properly...
                  is it because its 2.1.2 europe?
                    probably, 2.1.2 eu works different then 2.1.1 na. Ill take a look at it for you soon.
                    (withdraws igmod suggestion)
                      well iGmod may work in the end, if i can work out how to get iguidance to work in road runner first... but i cant... i followed the faq's correctly i fink.... but still doesnt seem to play ball.
                        maybe it's because 2.1.2eu has a different Window Name. Do what J187 said and post some screenshots.
                        iGMon - Integration between iGuidance and Road Runner
                        CFX - Skin for Road Runner
                          follow the FAQ in guino's how to embed any program in RR. Use winspector spy to find the windows name. I bet B8bboi is right about it having a unique windows name.
                          Please help.
                            Using latest 30/09/2005 Roadrunner and BMV2 skin
                            iNav iGuidance 2.1.2UK
                            J187 settings from above {
                            GPS Mode = External
                            See pic below.
                            It seems to work fine, somewhat quicker than MapMonkey/Destinator.
                            I can't get rid of the warning at the start about safe use, I need to click ok.
                            The "About" dialogue doesn't seem to have a close or exit button so you have to exit the program to get rid of it.
                            edit{
                            I used autoit to deal with the startup dialogue, as per SKINBedder 2.99999.
                            If you use this remember to change the "GPS Path" setting to point at the compiled autoit file.
                            Now just trying to get skinbedder to work but that's another thread }
                            That's it so far....
                            www.debthelpexpert.org
                              No need for AutoIT, just change the "ShowWarning" key at "HKEY_CURRENT_USER\Software\iNav\iGuidance Europe" from 1 to 0
                              Keep us posted.
                              Old setup
                              Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
                              New setup
                              Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
                              Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
