Playlist Refresh for Album folders
  • Playlist Refresh for Album folders
    Hey i was wondering if there was a way to refresh the playlist everytime a new song is played. i use a plugin for winamp called album folders that uses a keybinding to switch to the next or previous album. I wouldent mind useing this with roadrunner, but when i press the key to change the album, it changes it but in roadrunner it shows that im playing the first track of the previous album. i can get it to refresh by removing one song from the playlist, but i would like it if there was an automatic way to do it that dident involve me removing one song from the playlist
    brad
    If you can make the same key change album and trigger the "RELOADLIST" command it should work fine.. but since you're using that keypress with the plugin, RR may not be able to "catch" the same keys...
    Ride Runner RR's Myspace
      thanks for the info, even if the 2 bindings dont work together i dont mind that. im just glad to know there is a refresh like i was looking for. also not to sound dumb but i am new to RR and i do not know who to do what you sugested.I dont know how to set a keybinding with RR for its "RELOADLIST" command.
      Thanks again
      Brad
        never mind... i figured it out my self.. i guess i should of looked before i responded. found the ini, and it explaned how to do the keybindings verry well. As you thought they do not work at the same time, but binded to a seperet key it works perfect maby il just make macros or something to jerry rig it
        Thanks again
        Brad
