Can RR Run an external application on startup?
  • Can RR Run an external application on startup?
    If yes......... How?
    i believe it can, how, im not sure
    but... the more simple way to do it would be to use a bat file to launch RR and the other app you want to start. You can also set RR to kill the external app when it shutsdown via ExecTBL.ini
    beer replenishment fund
    mp3car live search
      You can use the start command option in RRConfig for this along with the RUN command -- details are in skin commands.txt.
      Ride Runner RR's Myspace
        Quick Q about this...
        Skin Commands tells me as an example:
        "RUN;C:\WINDOWS\NOTEPAD.EXE;NOTEPAD;NOTEPAD"
        What if my path to the App has spaces or is a long filename or something? Do I need extra quotes in the middle, or will it work fine just like that, or how do I do this?
        -arebelspy
        See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
        Originally posted by xdjxklusivex
        i think every thread is now a whoreing thread
          Looks like the first extra "notepad" in that example makes it embedded and the second makes it spoken.. i need neither, but when i try
          "RUN;C:\path to my app\app.exe" it doesn't work.. any suggestions anyone that knows more about the RUN command?
          EDIT: To give you more info, I'm basically setting rr as my shell, and want it to run a matchvolume exe at startup. it's located in a subfolder of "Program Files" (so path has a space and is a long filename).
          -arebelspy
            Tried it, doesn't work.
            Neither of these work:
            "RUN;C:\path to app\app.exe"
            "RUN;"C:\path to app\app.exe""
            Anyone have any experience with the RUN command and can comment?
            -arebelspy
              How about this
              It works for sure
              runq;C:\program files\freedrive\freedrive.exe|hidden
              I’m using this at the moment to load my gps program. The hidden option is for the gps program.
              The road is long but we are getting there.
                Hmm well I figured it out just before you posted that, but thank you, I really appreciate the help!
                I removed all quotes (around RUN, around long path with spaces, etc) and it worked.
                Thanks again though.
                -arebelspy
