RR 09-30-05 .. Quick update..
  • RR 09-30-05 .. Quick update..
    In this version:
    -Added ONFILECLICK and ONDIRCLICK selection events
    -Added ONPLCLICK and ONPBCLICK selection events
    -Added support to read Tracknumber from Winamp Library
    -Added support to display the Volume % of any audio line
    -Added LOADLIST command to load playlists
    -Fixed issue with last directory showing on wrong skins (mappoint etc)
    -Fixed issue with %station% on XM/SIRIUS display format
    -Fixed Video<->Audio path transfer issues
    Notes:
    -The ONXXXXX events allow you to execute a command when you click on a folder, file, playlist or phonebook item. Those are to be defined in ExecTBL.ini
    -LOADLIST is just a faster way to load a playlist from the disk, you can specify a title for it as well. This is mostly for SDK or for those who like making playlist presets
    -Also updated the SIRIUS station art and cache files with the new SIRIUS line up (Thanks to FerndaleGuy76 for the Art files)
    Thanks for your support,
    Guino.
    Ride Runner RR's Myspace
    Thanks Guino!!
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
      that will be really sweet for us remote users
      going to have to change my skin now
        Thanks guino
          Originally posted by hematec
          Thanks guino
          My car install
            I just installed the last two updates, i'm using Ls3.0 skins, and now when i go into music (or even to the next main screen), and try to back out with the menu button, i can't.
            Is anyone else having this problem..
            Besides this little problem... your program rocks guino !
            EDIT: The problem was me.. I didnt update the skins....
            Dual Lilliput's 70NP/C/T
            Syntax SV266AD KT266A
            AMD Athlon XP 2000
            Viking 256MB DDR
            D-Link Wireless 802.11B
            Seagate 120GB
            OrbitMicro 250W DC/DC converter
            SII Wireless Audio Link
            Digimoto OBD-II
            Earthmate GPS
            BU-303 USB GPS
            D-Link Bluetooth
              Your problem is not related to this update of RR.
              Go to Your RR Dir in \SKINS\LS3.0beta4\ExecTBL.ini
              open the file and remove the space at the beginning of the first line.
              This was the trick
              Fabio
              _______________________
              Travla C134
              Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
              RoadRunner - PC Navigator 7.1 - FreeFone
                I come here to point out that Sirius changed their lineup, and you've already released an update.
                I should have expected it. Thanks.
                  Thanks for the update Guino.
                  I'm still having problems with Winamp Library playlist display I'm afraid.
                  Using RR binary package 09/30/05
                  Using BMV2 08-08-05 unmodified
                  Playlists and directory browsing show tracknumber and title as per rr.ini settings
                  (id3listformat=%tracknumber% - %title%
                  id3browseformat=%tracknumber% - %title%) but browsing the library list shows directories only, no files. The files are there, I can even click on the blank list and choose files (I remember where they were ) but the playlist/directory list is blank.
                  The last working configuration was rr binary 09/25/05 with the same skin.
                  When library browsing the playlist displays titles (no track number as you said in previous thread).
                  If this is only affecting me I can carry on using 09/25/05 no problems.
                  www.debthelpexpert.org
                    can you post a shot ?
                      thanks for the updates, any word on when a random command can be implemented for video?
                        Originally posted by guino
                        In this version:
                        What are the labels I need to use to get these to work?
                        I have tried “cd” “line” ”Wave”
                        2001 S10 ZR2
                        Chucks Skin - to old
                          Hi,
                          i used the labels:
                          "VOLUME;Wave"
                          and
                          "Volume;Mic"
                          bye hematec
                            Thanks but for some reason it will not work on my machine – volume works but that’s it
                            2001 S10 ZR2
                              I've got the latest RR.exe and for some reason winamp won't shutdown properly. If I exit RR and the open it up again, it won't play any mp3s even if I select a different track or album. I have to open task manager and kill winamp.exe and THEN restart RR to get it to play.
                              CarPC #3: 99% Complete
                              Pentium M 1.7Ghz, 1GB DDR2 RAM
                              DVD/CD-RW installed in dash below monitor
                              OEM LCD relocated for 7" Touchscreen
                              Wi-Fi, GPS, PS2 controllers...
                              500+ full albums
                              4,000+ video games
                              music videos, movies, & more!
                              old carPC
