mute- unmute radio
  • mute- unmute radio
    I have cinergy600 , input line as "mic"
    In the RR config , setup "unmute mic"
    question :
    when updown the radio , the sound is open....
    when shutdown the radio ( return of main menu) the sound is open ???
    play the music , the sound of the radio is mixing for player for the music.
    Why ?
    In the latest upgrade of RR , the player menu , not exist, exist only selected menu.
    is well ?
    what command in the skin setting for play the song ?
    The "stereo" mode , in cinergy600 not exist?
    The RR + ZOT skin , very very beatiful !!! ;-))
    1-Using the Microphone as input will DECREASE SIGNIFICANTLY the quality of your RADIO.
    2-As long as you selected the Microphone line to mute/unmute in RRConfig it should work (As long as your sound card works right -- try updating drivers and such if you have issues)
    3-The Radio playback stays ON until you return to the Music Player or Open the VIDEO/DVD/XM/SIRIUS screen.
    4-The Cinergy card does not provide interface to know if a station is stereo or Mono, it only lets you FORCE it to one or the other (RR leaves it to auto select).
    I don't understand any of this:
    is well ?
    Ride Runner RR's Myspace
      [QUOTE=guino]1-Using the Microphone as input will DECREASE SIGNIFICANTLY the quality of your RADIO.
      ok , what using for input radio ? The only external input is mic... :-?
      The sound card is ok.
      the mic input is disactivates only when RR exit
      when music player is on , is on the radio.... Two sound in mixing ;-)
      VIDEO/DVD/ecc , is ok.
        I'd suggest making a cable using the CD-IN our AUX-IN plug commonly found on the motherboards .. the Mic quality is a lot lower because it is amplified from the low gain mics used on PCs.. This should also fix the issue with the mic line not muting when exiting Radio -- some cards just don't work right with the mixer interface.
          I want to use the mixvebes U46mk2 as a soundcard. It Doesn't show all the speaker outputs in win. speaker setup, But by using the 5.1 plugin for winamp all speakers work with mp3's. It online has a mic-in (input 1, 2, 3, 4 ) i want the radio to use input 1 and 2.
          With an other soundcard i found out, in order to get 5.1 sound, the radio needs to use the Line-in plugin in rr. I used: line://title=Radio,srate=48000,bps=16,nch=2 and the line used for mute disabled.
          Now my idea was to use mic://title=Radio,srate=48000,bps=16,nch=2
          But no sound. When i mute / unmute the mic there is sound output 1 and output 2.
          What do i need to change in to get the line-plugin to work with the mic?
          Cold weather mobo list: Copy the list and add your board
          my hidden screen in action (youtube) , the worklog , RR Volvoskin
            I found out the setting in windows of the recording device determent what line will be used. The u46 doesn’t have a selectable recording device, so that won’t work.
            The other soundcard, the terratec has a line in and a mic. Looking what’s the previous posts i want to use the line.
            I have selected the line in the recording options. Closed windows and than restarted the pc, this works. Then i have don the same with hibernate, works. The last thing i tried was the standby, doesn’t work. No matter how i select, when the pc is on it has changed the input from line in to mic. The only time it doesn’t do this is when i have opened the sound-icon an selected the recording tab. When that one is open it switches back on with te line in as the recording device.
            So there is 2 things i can do,
            1 have the sound-section start up with recording devices opened
            2 find the file where windows has the default recording input device.
            I looked in regedit, but no luck.
            Ideas are welcome.
