Set a pause with Sendkey command?
  • Set a pause with Sendkey command?
    I have to use the SENDKEY command to get Road Runner to work with MS Streets and trips, and I'm wondering if I can put a pause in the command. I don't see anything in the documentation about this, but it would make things a LOT easier and better if this could be done.
    Matt Atkins
    Seattle5s | President
    '01 M5 Lemans Blue/two tone black and silver interior
    Factory nav.... for now
    Old Car (almost sold)
    '98 540i-6 blk/blk
    Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
    you can do it like this
    The code below has 2 commands
    "PLAY||RUN;C:\LineWaveToggle.exe"
    FYI, the PLAY command is a toggle between play and pause.
    beer replenishment fund
    mp3car live search
      Oh, I didn't mean pause as in pause the music, I meant pause is in a delay before the next command.
      Something like "SENDKEY;%VT||SLEEP[2000]||SENDKEY;%VB"
      Reason being is, I'm usting MS Streets and Trips for my navigation software. I'd like to be able to send a command to turn GPS on, wait for it to connect, and then send another command to center the map around my current position (then another to rotate map)
      Matt Atkins
      '98 540i-6 blk/blk
        I'd say that when it gets to be like that, you're probably better off making an AUTOIT script to be executed by your button.. I believe AUTOIT would provide you with a lot more functions to control the application. FYI, no matter what, S&T will always suck -- That's why there's Mappoint. It's all a matter of how much you're willing to spend on your system.
        Ride Runner RR's Myspace
          Yes and no... I have Mappoint 2004, Streets and trips 2005, and Streets and trips 2006, and I have to say I like Mappoint the least. Streets and trips 2006 though is VERY cool. I'm going to get Mappoint 2006 when it comes out and if it's as good as Streets and trips 2006, then it would be great.
          My biggest problem with Mappoint is that it's not easy to have it tell you how to get somewhere from your current position. Reason being is, I have to right click on the map (um, try doing that on a touch screen) near where I am, select add to route, then go into route planner and add the point you want to go. Streets and trips allows you to just type in where you want to go and hit go. And, if you want to have it reroute you, you just hit the go button again.
          The thing I don't like about Streets and trips, is there is no way to set it up so that it automatically turns GPS on when you start the application
          Matt Atkins
          '98 540i-6 blk/blk
            Sorry but that's bull... Using Mappoint in RR, you don'e ever have to click on the map or know where you are, you just enter the destination to the route and hit calculate and the route is done, or just search nearby places, select it and hit calculate to go there -- again without even LOOKING at the map... and you even get turn-by-turn VOICE directions.. S&T has crappy and small controls... sure
              i would suggest HONESTLY just dump MS STEETS, its crapola, i have it also and it was just a waste of money. It as not designed to be used while moving, kind of retarded if you ask me since it is GPS software, but there seems to be a few of these packages that dont really offer any value or have built in features that purposely make using it in a car a pain in the ***.
              mp3car live search
                Sorry, I didn't mean you have to click on the map to know where you are, I'm talking about setting a route from your current position. Say, if I'm somewhere and I want to get home. I first have to set my current position by right clicking on the map near where I am, and then go into the Route planner to select my home address.
                I'm not sure if this is what you're sayign though..... I've tried simply entering where I want to go in route planner and hitting calculate (and/or optimize) and it does not give me a route from my current position. I just notes the point on the map and that's it. Maybe I have a setting messed up or something. If I could get it to function that way though, I'd like it a lot better... but I think I still favor the new Streets and Trips (I'm going to post a review after my first road trip yesterday in a few minutes)
                One thing I did notice with Mappoint however is, if you don't have any preset favorite addresses, and you bring up the blank favorites window and click select, it will put your current GPS position in the Route List (lat/lon). Not sure if this is a bug, but I kind of like to have preset addresses in my favorites list, and if you do, this trick doesn't work.
                Matt Atkins
                '98 540i-6 blk/blk
                  I have to disagree with you when it comes to Streets and Trips 2006. They really built this for in car use. I'd imagine there are some people on this board that work on that application for MS or at least forwarded on their requests to the team, because it is VERY driving oreinted now. I just did a ~400 mile road trip yesterday to Cape Flattery (Neah Bay, WA) and while I have a few complaints, it worked very well. Leaps and bounds better than S&T 2005.
                  However, Guino did give me some tips to use that AUTOIT program to do what I want, I think my problem will be solved. All I need now is to learn how to write in VB script. I've wanted to pick that up for a while (I'm a simple tester, not developer, or devloper in test,) but I've never had a good reason to do so... and now I do.
                  Matt Atkins
                  '98 540i-6 blk/blk
                    There has been a report of the single-route calculation not working when NOT showing the GPS position ... I can tell you right off that this feature only works with a GPS LOCK (duh)... but that's what I ALWAYS use so I know it works. In regards to the favs, the way to add the GPS position to the route is by pressing the Nearby button on the add location screen, entering a radius like 1 (one) and then selecting the GPS position from the list of locations.. The reason why it's there is because this is only usefull when you want to add multiple points to your route list (otherwise you'll most likely use single-point route..) ... in any case, this is probably why you like S&T, that is, you haven't gotten mappoint to work the way it should work.
                      Hmm... I'll play around with it some more and see if I can get it working. Still... Night mode is hard to pass up on Streets and trips. That, and I just found a cool StreetKeys application for Streets and trips at www.gpspassion.com.
                      Regardless, I'm sure Mappoint 2006 will be 100x better when it comes out.
                      Thanks for the Info Guino.
                      Matt Atkins
                      '98 540i-6 blk/blk
                        i cant really see how this is built for in car use. Sure i see that they are warming up to the idea and are starting to see thats what people want. But its still far from being in car ready. The biggest issue being the whole GPS pane, its actually worse than the older version because there are even more tiny check boxes you must click everytime to launch the app, which still include having to manualy tell it to start tracking you with GPS.
                        Some of the additions/changes are good and welcome for in car use, like the directions at the bottom nice and big, easy to see, but the night map mode is a mess. Sure it looks like some cool, military/sci fi looking map with black background and green everything, but IMO it makes the map actually harder to see the details with everything being green. I can easily find myself looking at that map at night and saying where the hell am i and what is all this green confusion. They should of just made it user configureable and been done with it, everybody happy.
                        A few other things missing i would consider needed for in car use is fullscreen maps, 3D mode, minimal interface etc. All of which are missing. Its allmost like they dont want to add more in car features as to not tempt people to use it while driving.
                        I can see the app getting better in the future, but how long will that take for them to catch up to apps allready geared for full time in car use? Not any time soon, it allways takes MS a while before they say, hey there is a real market here and we want to dominate it, then they pull out the big guns, but up till that point everything is allways just blah.
                        For 40 bucks or less though, its not a huge investment and for that price its damn good software, just needs a UI overhall and better application design. The maps are good, tracking is good, POI database is good, has traffic and weather (update via net), but just looks like an office app and not easy to use in a car.
                        mp3car live search
