RR is running really slow...
  • RR is running really slow...
    Hi!
    Today i did a fresh install on my desktop PC. I use it to test roadrunner and skins. Since then Road Runner runs really slow... I have to click on buttons 4-5 times before they work... Sometimes RR hangs completely. This is kinda strange, cause before the fresh install there was nothing wrong...
    I used the same software as before, only now updated versions.
    I use:
    Roadrunner
    Skin: LS3.0 ver4
    Winamp 5
    How is this possible? Did i miss something?
    Thanx for your help!
    AsRock AM2 dual VGA
    AMD Sempron 3000+
    512MB DDR
    3,5" 80GB harddrive
    Liliput 7"
    TFT 15"
    M2-ATX
    0% [OOOOOOOO-] 100%
    My install
    installed macromedia flash? newest version?
    Living the dream!
    AMD Athlon 1700
    512mb ram
    7 inch toch sceen
    wireless
    bluetooth
    GPS
    See my car and setup
    http://www.cardomain.com/ride/847490/1
    [++++++----] 60% finished
      installed this one,
      http://www.macromedia.com/shockwave/...ShockwaveFlash
      AsRock AM2 dual VGA
      AMD Sempron 3000+
      512MB DDR
      3,5" 80GB harddrive
      Liliput 7"
      TFT 15"
      M2-ATX
      0% [OOOOOOOO-] 100%
      My install
        I also noticed this today in my car setup.
        When playing some folders/mp3's kinda use abnormal performance. hit the next/forward button normaly plays next song, but after latest update it only forwards the slider. My car setup hasn't changed since february 2005. Tomorrow I'll try a fresh (RR) install to see if it solves any problems.
          ive been noticing similar issues... takes a while to respond when searching through a video file on the slider, doesnt refresh as fast anymore
          '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
            Diddo. I've noticed it to. Movie between menu selections takes a good 5 seconds. Latest updates and zots skin.
            Live mp3Car Facebook Chat
              strange... everything runs normal now... Sometimes it just happen again, slow running and system hanging (RR). Only option then is CTRL-ALT-DEL..
              AsRock AM2 dual VGA
              AMD Sempron 3000+
              512MB DDR
              3,5" 80GB harddrive
              Liliput 7"
              TFT 15"
              M2-ATX
              0% [OOOOOOOO-] 100%
              My install
                Anyone have any luck figuring this one out. My menu selection are all extremely slow when selected for the first time (5 to 10 seconds). I have installed the latest flash. I have even reinstalled windows (as my carpc is still on my desk being tweaked). I used a different version of windows xp pro this time. I still have the same issues, extremely high cpu demand when starting and selecting menu buttons in RR. (all buttons excepte "minimize" and "Day/night", and mute). I have checked my ini file, looks good to me.
                Also, maybe some has come across this problem. When I first touch the volume control (after rr boots), sound stops. I have to move the slider all the way to zero then back up to get sound. Once this is done volume controls function normally.
                  Which skin are you using, do you have the latest flash + OCX ? Can you post the first 3 lines of some of your .skin files ?
                  Your slider problem seems very much like a driver issue... some SB cards are known to have bad drivers... I'd suggest looking for an updated driver before anything.. RR only reports a slider at a certain location when/if it is being reported (from the drivers) as in that location... and it unmutes the line prior to any adjustments (exactly to prevent issues like yours)... I can only assume the sound card is saying the audio is at X% when you actually have no sound..
                  Ride Runner RR's Myspace
                    MEDIACAR Skin
                    MEDIACAR "audioplayer" Skin
                    audio_player_off.jpg,audio_player_off.jpg,audio_pl ayer_on.jpg,audio_player_down.jpg
                    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
                    B02,500,0,150,60,"VISU",
                    B03,300,520,100,80,"VOL-",
                    B04,400,520,100,80,"VOL+","Volume+"
                    B05,0,520,150,80,"PREV","Prev/FW"
                    B06,500,520,150,80,"PLAY","Play"
                    B07,650,520,150,80,"NEXT","Next/FF"
                    B08,150,520,150,80,"STOP","Stop"
                    B09,175,217,200,200,"LOAD;Audio_List.skin",
                    B10,0,0,150,60,"EXIT","Exit"
                    /, I, x, y, w, h, Code;INDICATORCODES
                    I,675,118,80,30,"REPEAT"
                    I,675,87,80,30,"SHUFFLE"
                    B12,150,0,150,60,"MIXER",
                    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
                    L01,74,133,600,30,192,192,192,20,"Decker:B","TAGAR TIST","SCROLL-LEFT"
                    L02,74,83,600,40,255,255,255,28,"Decker:B","TAGTIT LE","SCROLL-LEFT"
                    L04,75,351,80,30,254,5,0,14,"Decker:B","KBPS","Tra ck bitrate"
                    L05,75,307,80,30,254,5,0,14,"Decker:B","KHZ","Trac k freq"
                    L06,75,394,80,30,254,5,0,16,"Decker:B","TAGYEAR",
                    L08,409,486,50,30,255,255,255,16,"Decker","VOLUME" ,"LEFT"
                    L10,75,262,80,30,254,5,0,14,"Decker:B","CURRENTTRA CKTIME","Current track time"
                    L11,75,215,80,30,254,5,0,14,"Decker:B","TRACKTIME" ,"Total Track Time"
                    L12,633,487,40,30,255,0,0,16,"Decker","=ETR","RIGH T"
                    L,41,487,60,30,255,0,0,16,"Decker","=CPU","RIGHT"
                    L,183,487,50,30,255,0,0,16,"Decker","=CASE","RIGHT "
                    L13,500,487,40,30,255,0,0,16,"Decker","=ETA",
                    L14,343,486,50,30,192,192,192,16,"Decker","=Vol"," RIGHT"
                    L,686,487,60,30,255,0,0,16,"Decker","CUSTOMFDETR", "LEFT"
                    L,552,487,60,30,255,0,0,16,"Decker","CUSTOMFDETA", "LEFT"
                    L,641,422,100,40,255,255,255,24,"Decker","=Km/h","LEFT"
                    L,531,422,100,40,255,255,255,24,"Decker","CUSTOMFD SPEED","RIGHT"
                    L22,413,333,330,40,255,255,255,22,"Decker","CUSTOM FDROAD","LEFT"
                    L,637,304,100,20,192,192,192,14,"Arial","=Satellit es","LEFT"
                    L23,588,304,40,20,255,255,255,14,"Arial","CUSTOMFD SATS","RIGHT"
                    L24,532,379,200,30,255,255,255,18,"Decker","CUSTOM FDNEXTMAN","LEFT"
                    L25,415,379,100,30,255,255,255,18,"Decker","CUSTOM FDNEXTMANDIST","LEFT"
                    L15,75,437,300,30,255,255,255,18,"Decker","TAGALBU M","SCROLL-RIGHT"
                    L16,113,487,52,30,255,0,0,16,"Decker","MbM1","0.0C "
                    L17,247,487,52,30,255,0,0,16,"Decker","MbM2","0.0C "
                    B,473,205,250,60,"SHUFFLE/REPEAT",
                    B11,400,294,350,150,"GPS",
                    /, J, x, y, w, h
                    J01,175,217,200,200
                    /, A, x, y, w, h, color;RGB
                    A01,30,170,740,310,000
                    END
                      Still frustrated with the slow launch times, I went and uninstalled version dated 10/7/05 and put back version dated 5/12/2005.
                      All is back to normal now (about 3 to 4 times faster launching menu buttons).
                      In addition, the volume slider issue I was having is no longer.
                      I'm using the BMV2 and Zots skins just downloaded from the rr page. So far no issues.
                      If I can't get the newer versions to run right on my system, what major features will I be lacking?
                        My RR is also very slow after i last reinstalled windows.
                        4G64 5 SPEED
                        MY CAR - MY 5SPD - MY CARPUTER - MY GARAGE SALE
                          MEDIACAR Skin
                          Whats up with that. Im seeing ****. there is a space between "audio_pl" and "ayer_on.jpg" but when i quote it it fixes itself.
                          Anyone else see that or have i been up too long? If im not seeing things then TheKingPlazza: is that how the file has it too?
                          Um, I guess this is where you put something witty.WITTY
                          My Web site, in the design stage. http://home.comcast.net/~cstrachn
                          Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
                            Yep I'm also seeing the space
                            The road is long but we are getting there.
                              I had the same problem too... I did a fresh install of windows yesterday, the volume problems are over now...
                              RR is running slow as in my previous install, i also used another Win XP Pro cd.
                              AsRock AM2 dual VGA
                              AMD Sempron 3000+
                              512MB DDR
                              3,5" 80GB harddrive
                              Liliput 7"
                              TFT 15"
                              M2-ATX
                              0% [OOOOOOOO-] 100%
                              My install
