send commands to apps not working?
  • send commands to apps not working?
    im trying to get RR to launch and app and also send commands (switches) to the app but it dosent seem to be working, when i use any commands RR fails to launch the app and just sits there.
    In the "Skin Commands.txt" file it says
    "Dynamic Commands: set the code of a button to: "RUN;COMMAND+PARAMETERS" will
    make it so clicking this button runs the specified command&parameters in the computer."
    ive tried using the plus symbol and also the "&" symbol but no dice.
    when i use the commands on a windows shortcut they work fine, the full command line is below. Note, this is used only on a windows shortcut. What it does is open Opera with all UI elements turned off, including the file menu
    "C:\Program Files\Opera\Opera.exe" /kioskmode /kiosknormalscreen /nomenu /nopanel
    ive even tried it only using one command but RR still doesnt like my code.
    here is the RR code
    "RUN;C:\playfile.exe|C:\Music.wav||LOAD;opera.skin ;RUN;C:\Program Files\Opera\Opera.exe+/nomenu;Opera"
    anybody have any ideas?
    thanks
    beer replenishment fund
    mp3car live search
    I think you still need a Double Pipe in there and get rid of the plus sign.
    Try this command:
    "RUN;C:\playfile.exe|C:\Music.wav||MENU;opera.skin ||RUN;C:\Program Files\Opera\Opera.exe /nomenu;Opera"
      no dice
      not sure why nothing happens
      mp3car live search
        it has something to do with the commands being sent to the app,
        this works
        "RUN;C:\playfile.exe|C:\Music.wav||LOAD;opera.skin ;RUN;C:\Program Files\Opera\Opera.exe;Opera"
        but this dosent work
        "RUN;C:\playfile.exe|C:\Music.wav||LOAD;opera.skin ;RUN;C:\Program Files\Opera\Opera.exe /nomenu;Opera"
        the only difference is the /nomenu
        mp3car live search
          TRy
          "RUN;C:\playfile.exe|C:\Music.wav||LOAD;opera. skin ;RUN;C:\Program Files\Opera\Opera.exe|nomenu;Opera"
          2001 S10 ZR2
          Chucks Skin - to old
            pay attention man:
            "RUN;C:\playfile.exe|C:\Music.wav||LOAD;opera.skin ;Opera;C:\Program Files\Opera\Opera.exe|/nomenu;Opera"
            you mixed up the load command and the run command inside of it...
            Ride Runner RR's Myspace
              lol consider yourself TOLD..
              Follow me on Twitter
              http://www.FreeICE.co.uk
                Originally posted by guino
                pay attention man:
                almost forgott i was even having issues with this. Its late now though, ill check it out in teh morning.
                mp3car live search
                  Okay, so I'm trying to get Mobile Emulator to run inside of RR, and I was told I need to add this button (and the associated string of commands/parameters):
                  B06,3,312,275,78,"RUN;C:\playfile.exe|C:\Music.wav ||LOAD;games.skin;RUN;C:\Program Files\Mobile Impact\me.exe;Mobile Impact",""
                  But I'm not sure where this should go. The file to RRSource.zip seems to be down. Can I get a little help?
                  CarPC #3: 99% Complete
                  Pentium M 1.7Ghz, 1GB DDR2 RAM
                  DVD/CD-RW installed in dash below monitor
                  OEM LCD relocated for 7" Touchscreen
                  Wi-Fi, GPS, PS2 controllers...
                  500+ full albums
                  4,000+ video games
                  music videos, movies, & more!
                  old carPC
                    Where?
                    Hi,
                    From the look of it that's a button command and should go in menu.skin in your skin folder. Always make a copy of your skin and call it something different, and work with the copy. Remember to change RR config to the new skin name! Don't ask me how many times I've forgot that!
                    Cheers,
                    Gavin.
                    Stuff: Via M10K, 60Gb 2.5", Sony slim combo, Travla case, carnetix PSU, Shuttle Express,12" tft!
                    Progess: Fitted,Works,Looks kinda ugly!
                    Prizes to date: Winner of Most Ghetto, Digital Car meet Oct'05!!
                      Ok, my mistake the playfile is not needed (nicked the code from liquid smokes skin)
                      B06,3,312,275,78,LOAD;games.skin;RUN;C:\Program Files\Mobile Impact\me.exe;Mobile Impact",""
                      this is a button command in one of your skin files.
                      Basically you need to create a button on a skin and put that code in.
                      Then you need to have a games.skin file and the associated skins to go with it.
                        hahaha... I still see a mix of the load command and the run command with the impropper separator ( instead of || as it should be... you can launch applications using the LOAD command ONLY or using the RUN command SEPARATELY from the Load command... but in no way the RUN command should be "part" of the LOAD command as you guys have been posting here..
                          so it should be
                          B06,3,312,275,78,LOAD;games.skin;games;C:\Program Files\Mobile Impact\me.exe;Mobile Impact",""
                          then?
                            the upcomeing update of the skin has support for mobile emulator and a skin for mobile emulator to use with road runner.
                            The code for that button that im using is this
                            "RUN;C:\playfile.exe|C:\Music.wav||LOAD;N64.skin;R UN;C:\Program Files\Mobile Impact\Me.exe;Game Emulator"
                            works everytime for me.
                            mp3car live search
                              Originally posted by Enforcer
                              so it should be
                              B06,3,312,275,78,LOAD;games.skin;C:\Program Files\Mobile Impact\me.exe;Mobile Impact",""
                              then?
                              so only the path to a file is needed to run it? Ive been using the run command with load on a lot of stuff.
                              mp3car live search
