External GPS - Running the Program multiple times
  • External GPS - Running the Program multiple times
    Hello,
    I'm using RR and I love it!
    I'm having a bit of an issue though. I use an External GPS program known as iGuidence.
    It open and runs correctly, however, when I minimize it to say.. play MP3s, then click on the GPS icon to return to it again, it opens a new instance of iGuidence.
    Is this a known issue? If so, how do I fix it.
    If not, can I get this added to the next patch release?
    Cheers!
    Aaron
    what skin are you using?
    This shouldnt happen, many peeps here use IG (including me) and it never opens twice on my machine.
    Can you post the code used in whatever skin your using that opens your GPS.
    beer replenishment fund
    mp3car live search
      you most likely have the wrong window name setting in RRConfig, which makes RR look for the wrong window and since it doesn't find it, it tries to launch it everytime you press the button...
      Ride Runner RR's Myspace
        I'm using a modified BMV2 skin.
        Hmm, I'll take a look at the code, but I didn't change anything.
        Cheers
        Aaron
        menu.skin
        MEDIACAR Skin
        MEDIACAR MainMenu Skin
        menu_off.jpg,menu_off.jpg,menu_on.jpg,menu_down.jp g
        /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
        B01,11,105,145,106,"AUDIO","Audio player"
        B03,650,105,145,106,"VIDEO","Video player"
        B04,11,235,145,106,"LAUNCH",""
        B05,650,235,145,116,"DVD",""
        B06,11,365,145,106,"XM",""
        B08,650,365,145,106,"GPS","GPS"
        B10,160,500,65,97,"MUTE","Mute"
        B11,226,500,63,97,"VOL-","Volume-"
        B12,515,500,63,97,"VOL+","Volume+"
        B13,581,500,61,97,"MIXER","Mixer settings"
        B16,11,500,145,97,"GAMMA","Gamma mode"
        B19,645,500,145,97,"EXIT","Exit"
        /, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
        S01,290,545,223,35,290,545,223,35,H,01,"POINTER2.g if",013,"MASTER","Master"
        /, I, x, y, w, h, Code;INDICATORCODES
        I01,185,535,30,35,"MUTE:b"
        /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
        L10,175,52,470,45,255,255,0,26,"Arial Narrow:B","TRACKNAME","SCROLL-CENTER"
        L00,415,515,50,30,255,255,255,13,"Arial Narrow:B","VOLUME","Volume"
        L01,30,10,135,30,255,255,255,18,"Arial Narrow:B","TIME","Time"
        L02,660,10,135,30,255,255,255,18,"Arial Narrow:B","DATE",""
        END
          Got it, you were right, I had the wrong window name.
          Works perfect now! Thanks so much!
          Cheers
          Aaron
