Phone button to bring Phoco in front of RR
  • Phone button to bring Phoco in front of RR
    Hi guys,
    I want to run RR and Phoco seperate as there are more features available with Phoco as a stand alone.
    All I need is when I push the Phone button in RR the already running but hidden Phoco pops up.
    I looked at the commands in the RR skin editor but cant figure it out.
    Sound Stage
    Eclipse|MTX|Infinity
    I think if you just set a RUN command it will pull the already open PhoneControl to the fore.
      "RUN;C:\Program Files\PhoneControl.NET"
      no workie
      Sound Stage
        You haven't got the exe on the end of that path.
          What happens when you are in RR and a call comes in. Will the phoneco popup show? Also how do you switch back to RR?
          Have been trying this out myself and have the problem that the popup is not shown above.
          Any suggestions ?
          VIA EPIA M10000 LVDS 1Ghz Motherboard,
          256Ram,80Gig,
          Lilliput 7" In Dash Touchscreen
          Panasonic Slimline Slot-in Cdrw/dvd Player,
          USB Gps Reciever,
          Belkin Bluetooth dongle
          Belkin USB wifi
          Carnetix CNX-P1290 60W Power Regulator
            Even with .exe does not work.
            Sound Stage
              Any suggestions ?
              Just need to find a way to push the Phone button in a RR skin and Phoco goes in front of RR to make a call. You can minimize phoco after you are done. There is a setting in Phoco for hidden when not in use and when it first starts up.
              Phoco will show when a call comes in no problems without the popup button
              Sound Stage
                This command should run phoco and also bring it to front, remember to include the quotes.
                "RUN;C:\Program Files\PhoneControl.NET\PhoneCtl.NET.exe"
                also, since you guys are talking about this, how do you get rid of that button that shows up when you minimize phoco?
                beer replenishment fund
                mp3car live search
                  Thanks liquid It is working .... sort of I don't think Phoco likes being handled this way. As long as you do not minimize Phoco you are ok. But once you do, it will not maximize again. I have asked Zorro if it is possible to create a button on the Phoco screen that will replace the minimize button in Phoco and add a Run=C:\programs\RoadRunner\Roadrunner.exe command to the button. .
                  But the code is right. Thanks again!
                  Sound Stage
                    Out of curiosity, what enhancements are you getting out of doing it this away? If you run it remotely/embedded from RR what are the downsides??
                    I have the single BT connection problem with Phoco/RR on a Motorola type phone but the rest of it is working fairly well.
                    The TCP/IP remote calls on port 17xx can slow things down a bit on the CarPC when connected to a full LAN/WAN network and Internet.
                    If you have Phoco running and want to use the Phone for a DUN, then that causes problems.
                      it works for me when phoco is minimized, only problem i havent ever been able to figure out is how to get rid of the button that shows up when you minimize phoco
                      there is also a switch to window command in phoco, it works a little weird as in i think you cant shut phoco down, it has to be killed by another app.
                      mp3car live search
                        Set the button to false.. worked for me. He also got back to me about how to create a button to go back to RoadRunner
                        From Zorro:
                        Open the configuration file with Extended Configurator, then set PopupOnHide to False (MainWindow section).
                        How to give the window back to RR:
                        Have a look at WindowToSwitchTo : http://zhorvat.dyndns.org/PCForums/S...aspx?PostID=39
                        Use "RoadRunner".
                        Sound Stage
                          From Zorro:
                          Use "RoadRunner".
                          ah, that works. I didnt know that button was called "PopupOnHide", i was trying to find it in the skineditor.
                          mp3car live search
                            Up to the last update of RR which I have not tried yet, was not able to use the headset function properly when using bluetooth and Phoco and RoadRunner, also the skin I was using did not have signal strength, or battery useage.
                            With Phoco stand alone the headset automatically connects on in comming calls and will disconnect when done, or if I want to I can hit a button and headset is turned off and I can pickup the phone.
                            I also like the fact that I can shutdown Phoco if needed but have RoadRunner still going or visa versa.
                            Sound Stage
                              No problem also, I needed to change
                              Use Taskbar=true
                              in Phoco now it responds EXACTLY as you said it would.
                              Thanks Liquid for your help!
                              Sound Stage
