Is there a way to disable RoadRunner splashscreen
  • Is there a way to disable RoadRunner splashscreen
    during program launch?
    Got it, thanks.
      I read this=
      -There's a "loading banner" now -- I guarantee you that it will not slow down the start process in any way, but it will tell you what's going on. I did this so I could discard unused code from memory after loading, plus, give some user feedback. You can disable the Loader using the (Quiet) command line parameter: /Q
      I don't understand it though, where would I put the /Q
        The shortcut you use to launch it.
        -arebelspy
        See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
        Originally posted by xdjxklusivex
        i think every thread is now a whoreing thread
          I put in "C:\Program Files\Road Runner\RR.exe"/Q in my shortcut and windows gives me
          The name "'"C:\Program Files\Road Runner\RR.exe"/Q' specified in the target box is not valid. Make sure the path and file name are correct.
            "C:\Program Files\Road Runner\RR.exe"/Q is wrong....
            it should be
            "C:\Program Files\Road Runner\RR.exe /Q" (notce the space between exe and /Q
            Roy
            2005 Range Rover 4.4
              ps: test it out using the Start->Run option
              Roy
                that gives the same error, also when I try it from run
                C:\Program Files\Road Runner\RR.exe will work but
                C:\Program Files\Road Runner\RR.exe /Q will not work
                  Yup, need switch options w/i the quotes.
                  -arebelspy
                    you need quotes, as said above!
                    copy exactly this:
                    into the run dialog and try it
                    Roy
                      this in the run dialog
                      gives me this
                        does it work without the /Q ?
                        Roy
                          yes
                            I just tried it on another pc with windows xp and the latest version of RR, could it be an issue in the latest version of RR?
