wave 100% at song start
  • wave 100% at song start
    wave volume 100% at song start
    can anyone tell me what it is the problem? thank you!
    gonna need a little bit more info.
    do you turn the volume down, exit RR, restart RR and the volume is back at 100?
    does the volume jump to 100 when you change tracks?
    need to narrow this down.
    beer replenishment fund
    mp3car live search
      "does the volume jump to 100 when you change tracks?"
      yes exactly
        when track is starting to play or track is changing... wave volume is set to 100%. Really dont like it... my english is too bad.. maybe i cant describe this perfectly.. but I have two options. Using wave to controll volume by blaupunkt IR or using mastervolume. Master volume controls only front speakers. And wave is set to 100% everytime, when rr starts to play anything...
          anyone knows?
            i have had similar problems using the kxproject drivers for soundblaster pci card, and 4.1 spkr setup... id appreciate any help
            Roy
            2005 Range Rover 4.4
              yes exactly
              very odd. what kind of sound card do you have? Does this only happen with RoadRunner? What about if you load winamp standalone or windows media player?
              mp3car live search
                I have M10000 and i use the integrated audio card.. I dont know if it happens only in RR but i know it didnt happen with using master or rear speakers instead of wave.
                But now it isnt important for me because my HDD is dead. I have it in good anti-shock mount, but i think the temperature(winter) has killed it look at my mounting:
                  that sucks about the HD, just went through something similar a few weeks back.
                  people seem to have odd audio problems with those itx boards, i would grab a usb soundcard.
                  mp3car live search
                    Master level set to zero when changing volume in RR
                    I have a similar problem. When I change the volume in RR the master level (the one you can access from the systray speaker icon) is set the zero. If I go into the mixer page in RR and chnages from pop to Rap or similar the volume gets right again. Its a little bit frustrating.
                    Anyone have a solution to this? Does it have anything to do with the pre-set mixer settings files?
                    Cheers
                    /Henrik
                      i have this same problem. so no one figured out how to fix it?
                      wave at 100% distorts the sound quality quite a lot
                      i am using my m1k sound card outputting to asio4all.
                        open winamp and check if you have the "AUTO" preset loading on.. if anything just try winamp outside RR and see if the volume behaves in the same manner. There's nothing in RR that will do that. If anything, try the FMOD player in the new RR and see if that happens.
                        Ride Runner RR's Myspace
                          I experience this too.
                          But when I only play .mp3 files all the time, the volume is maintained at say, 20%. Then when suddenly the song switches to .wma, the volume goes up to 100%. I have to manually lower the volume then to 20%. When it changes to another .wma, it goes up to 100% again.
                          New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
                          SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
                            If you get it on winamp ALONE (outside RR), then you need to figure out wha'ts messed up with your winamp... try a different version of it, or uninstall it completely, delete it's folder and re-install to see... if anything, play with the input plugins' settings..
                              Has anyone figured out what's causing this? Winamp doesn't do it outside of RR... so I'm not sure what to look for
