iGuidance 2.1.3 - Warning Screen Issue
  • iGuidance 2.1.3 - Warning Screen Issue
    Hi there,
    I noticed that since I have upgraded to iGuidance 2.1.3, the warning screen that comes up the first time the application is opened does not close automatically anymore.
    Is anyone else seeing this? Is there a known fix?
    Cheers
    Aaron
    I had the same problem.
    It fixed it by installing the english version.
    I would like to use and did use the dutch version and i had the same problem
    I guess it is something in the lang. modules.
    If you already installed the english version i can't help you.
      I'm using English / NA.
      Cheers
      Aaron
        I guess no one else has this issue?
        Cheers
        Aaron
          rr was closing it automatically for you? try creating an autoit script and see if that resolves it for you.
          Dr. Ron Paul for President 2008
          Hope for America - http://www.ronpaul2008.com
          Who is Ron Paul? - Why do we need Ron Paul?
          CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
            It used to...
            Great!!! I'll try that straight away...
            Cheers
            Aaron
              Worked great, thanks for the info on the application.
              PS If anyone else needs this, PM me and I can send you the EXE I created.
              Cheers
              Aaron
                Well, it doesn't seem to like to run the exe in RR.
                It just opens up an explorer window....
                Any ideas?
                Cheers
                Aaron
                  Here's what I use to fire up iGuidance. The AutoIT compiled .exe resides in the same folder as iGuidance.exe
                  Code:
                  Run("iguidance.exe")
                    WinWait ("","OK")
                    WinActivate("","OK")
                    WinWaitActive("","OK")
                  Send("{ENTER}")
                  If WinExists("Warning","GPS") Then
                    WinActivate("Warning","GPS")
                    Send("{ENTER}")
                  EndIf
                  What Explorer window is RR trying to embed?
                    This kicked up a bunch of code errors when I ran it. Looks like it didn't like the " " in the code.
                    It's trying to embed the location of the iGuidance.exe
                    Cheers
                    Aaron
                      I think there was an issue with applications running in RR like this. For example iGmod in RR...
                      Cheers
                      Aaron
                        it's trying to embed the c:\program files\inav\iguidance folder?
                        is the folder open in explorer when you're trying to embed iguidance?
                        If so rr is probably grabbing the first window with the title "iguidance" (which would be the folder window that's already open.. make sure you don't have the iguidance folder open.
                        otherwise i have no idea, i'm a satisfied centrafuse user
                          I used this code:
                          Run, iGuidance.exe, C:\\Program Files\\iNav\\iGuidance
                          WinWait, ,OK
                          WinActivate, ,OK
                          WinWaitActive, ,OK
                          Send, {ENTER})
                          It worked great, but in RR I get the same issue of just opening an explorer window in the C:\Program Files\iNav\iGuidance directory...
                          Any ideas?
                          Cheers
                          Aaron
                            Hmmm, well I closed everything down.
                            First time it did the same behaviour... Tried it again, and it all worked and I couldn't repeat it.
                            Probably as you say, some weird thing with a current window open.
                            Thanks for your help!
                            Cheers
                            Aaron
