System lock menu
  • System lock menu
    Today I made a lock menu to keep the kids from playing with the pc when I am not in the truck.
    I use switch button for the combination. (5-5-5-5-5)
    I thought you could use switch button from one button to switch the command code on another button if so can someone help with a sample?
    2001 S10 ZR2
    Chucks Skin - to old
    yes, you can use switchbutton to switch the code of ANY button, including itself... the only trick is that you should number your buttons from top down, starting from 1 and make sure THEY'RE IN ORDER .. cause otherwise, the number you use with switchbutton will not match up the "logical number" of the button inside RR (Which goes by counting the number of B lines -- regardless of the number in front of it)...
    Ride Runner RR's Myspace
      Here is what I have now (5-5-5-5-5-5) then it exits the menu
      B0,135,303,115,65,"",
      B1,18,107,115,65,"",
      B2,135,107,115,65,"",
      B3,252,107,115,65,"",
      B5,135,171,115,65,"SWITCHBUTTON;5>>SWITCHBUTTON;5> >SWITCHBUTTON;5>>SWITCHBUTTON;5>>SWITCHBUTTON;5>>S WITCHBUTTON;5||EXIT",
      B4,18,172,115,65,"",
      B6,252,172,115,65,"",
      B7,18,236,115,65,"",
      B8,135,237,115,65,"",
      B9,252,237,115,65,"",
      What I am trying to is push button 5 times then on the sixth push switch button 1 to code "exit" so the combination would be 5-5-5-5-5-1
      “SWITCHBUTTON;5>>SWITCHBUTTON;5>>SWITCHBUTTON;5>>S WITCHBUTTON;5>>SWITCHBUTTON;5>>SWITCHBUTTON;1>>EXI T”
      2001 S10 ZR2
        see... you're labeling your buttons from ZERO and trying to switch button 5 which may or may not match up the button you want... the number in front of the B letter doesn't mean squat... it's the INSTANCE of the button that counts.. on your example "SWITCHBUTTON;5" should work... but "SWITCHBUTTON;1" would actually switch the code in B0... which is empty on your example..
          Man I tried every thing I can think of but no dice
          /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
          B1,18,107,115,65,"",""
          B2,135,107,115,65,"",""
          B3,252,107,115,65,"",""
          B5,135,171,115,65,"SWITCHBUTTON;5>>SWITCHBUTTON;5| |EXIT",""
          B4,18,172,115,65,"",""
          B6,252,172,115,65,"",""
          B7,18,236,115,65,"",""
          B8,135,237,115,65,"MUTE",""
          B9,252,237,115,65,"",""
          B0,135,303,115,65,"SWITCHBUTTON;9||EXIT",""
          Testing switchbutton
          Trying to change B9 from nothing to “EXIT” by pushing B0
          B0-"SWITCHBUTTON;9EXIT",""
          B0-"SWITCHBUTTON;9;EXIT",""
          B0-"SWITCHBUTTON;9,EXIT",""
          B0-"SWITCHBUTTON;9>>EXIT",""
          B0-"SWITCHBUTTON;9|EXIT","”
          B0-"SWITCHBUTTON;9||EXIT",""
          Even tried
          B9,252,237,115,65,"!MYBUTTON9",""
          B0,135,303,115,65,"SETBUTTON;!MYBUTTON9;EXIT",""
          B0,135,303,115,65,"SETLABLE;!MYBUTTON9;EXIT",""
          If I could figure this out the combinations possibilities would be unlimited – but all you would have to do is hit ESC, but I am not telling if you don’t
          2001 S10 ZR2
            you're really mixing up things man... switchbutton will "ROTATE" the code of the button you specify -- it will NOT replace the code with something else you give out... for instance:
            B1,.....,"VOL+>>VOL-",""
            B2,.....,"SWITCHBUTTON;1",""
            At first, B1 will work as VOL+ and that's it.... but then once you press B2 (The other button), the Code of B1 will work as VOL- .... until you press B2 again, and then VOL+ gets back into work IN B1... note that pressing B2 on the example above will have no "apparent" effect, that is, until you press B1 and see the results... so basically, the codes that switch are the codes between the >> of the button you're switching... and you can have the button alternate between as many codes as you'd like...
            IF you want B9 on your skin to swtich from "NOTHING" to "EXIT" then you'd have to have it like this:
            B9,.....,">>EXIT",""
            Then the first switchbutton would set B9 to "EXIT" and the next switchbutton would set it back to NOTHING (could be done along with the EXIT so it "resets" it)...
              Thank you guino !!
              Now you made it look easy
              I think I can work with this now
              2001 S10 ZR2
                Ok it works good
                Now I am working on the code to simplify so it will be easy to change the combination.
                Combination is 1379 and if you get it messed up just hit 0 twice to reset
                B1,18,107,115,65,"SWITCHBUTTON;9||SWITCHBUTTON;1>> >>>>EXIT",""
                B2,135,107,115,65,"SWITCHBUTTON;11||SWITCHBUTTON;2 >>>>>>EXIT",""
                B3,252,107,115,65,"SWITCHBUTTON;9||SWITCHBUTTON;3| |SWITCHBUTTON;1>>>>>>EXIT",""
                B4,18,172,115,65,"SWITCHBUTTON;11||SWITCHBUTTON;4> >>>>>EXIT",""
                B5,135,171,115,65,"SWITCHBUTTON;11||SWITCHBUTTON;5 >>>>>>EXIT",""
                B6,252,172,115,65,"SWITCHBUTTON;11||SWITCHBUTTON;6 >>>>>>EXIT",""
                B7,18,236,115,65,"SWITCHBUTTON;9||SWITCHBUTTON;7|| SWITCHBUTTON;3>>>>>>EXIT",""
                B8,135,237,115,65,"SWITCHBUTTON;11||SWITCHBUTTON;8 >>>>>>EXIT",""
                B9,252,237,115,65,"SWITCHBUTTON;11||SWITCHBUTTON;7 >>>>>>EXIT||ACTIVATE;RoadRunner",""
                B0,135,303,115,65,"SWITCHBUTTON;11||SWITCHBUTTON;1 0>>EXIT||MENU;LOCK_MENU.skin>>>>EXIT",""
                B11,-20,-20,1,1,">>",""
                2001 S10 ZR2
                  Here is my RR lock and the combination is 1379 and to reset it push 0 two times.
                  This is the button command to start it "MENU;LOCK_MENU.skin"
                  See if you can find another combination to open it.
                  I think I have it so no other combination will open it
                  2001 S10 ZR2
